URGENT!!! Help needed ASAP!!
We are in the middle of installing a first gen B16 into an 88 CRX Si. We are having 2 problems. First is the axles, they are the ones that came with the swap. They seem to fit perfectly, except that when you tighten the axle nuts down, the wheels won't turn. What parts do I need to change, the spindles or the axles? And which do I replace them with?
The second problem is that the car idles at 3000 RPM. We have tried everything. Anymore suggestions?
Thanks in advance.
Colin
Thanks in advance.
Colin
