fs: b series turbo kit and more!
I'm giving this one last shot on here before my lazy *** puts this all on ebay.
At the moment I need $$$ but partial trades will be considered....
You can make an offer if you want, the most i can do is turn it down, but i've lowered all my prices and am pretty firm on them.
The main stuff i'm interested in trading for include are cf hood, hatch, duckbill for an EG hatch and possible a type r flywheel
***PM IS KEY***
Send me a message with any questions/concerns/offers.
Call me at 859.653.0123 if you want to get ahold of me sooner, i work alot so if I don't answer just leave me a messge and i'll call you back at my first free moment.
First off B series turbo kit for eg/dc-idk how the piping will fit w/ef's and ek's-it is COMPLETE and will NOT part out, also is ac/ps combatable.and yes, this was bought from "all motor" and used by me for ~1 year. It is all still in great condition, everythign works fine and the turbo has minimal shaft play.
includes:
-turbonetics t3/to4e turbocharger- .63 a/r w/ .48 a/r exhaust.polished housing. good condition, minimal shaft play. we think it's a .57 trim, but not sure, there has been confusion with this.
-log syle maifold and 2.5'' dp. has o2 bung and is heat wrapped.manifold is tig welded (pics soon) except for wg flange.
-tial 38mm wg-polished includes either ~3lb spring or ~8lb spring. has dumptube-open loop
-HKS ssqv bov-previously another color and has been wet sanded and polished, looksnew
-IC piping is 3'' on cold side and 2'' on hot side. fits well, in good condition. is painted with heat resistant black paint.
-FMIC-ebay bar and plate-decently sized, will get the job done
-HKS muchroom filter
-Apex'i 60mm boost gauge
-tapped b series oil pan
-ALL oil lines and t fitting for block-all -AN fittings
-RC 440cc injectors
-Synapse missing link
-ALL vacuum lines and vacuum manifold
-walboro 255 fuel pump
If someone will be using this with an ls I can throw in the chip for it-tuned by Dave Blundell on ~12psi made 245whp&210ft/lbs on a mustang dyno. Conservative tune, average about 25~27mpg.
This setup has been very good for me and i cannot complain about a thing. it's made my car very quick and many people here can vouch for it. with this setup i've beat a 97 cobra, newer trans am, newer gto, 94 tt supra...etc...
***$1700***
--Worked p75 (ls) head-fully ported and polished, deshrouded valves and polished combustion chambers. Includes stock valves,springs,and retainers installed, has all original cam caps, and rocker arms. has not been milled, so that maybe necessary. I can take a straight edge to it for possible buyers. Also, i can mic the id's of the ports and compare them to stock ls and pr3 ports.
***$175***
--LS head-complete minus cams and rocker arms.
***$20***
--moroso ls valve cover, polished aluminum and badass,retails for ~300ish. It has a small scratch on the bottom, but it could be buffed out and is covered up by the spark plug wires anyways.needs gasket from moroso.
***$100***
--I also have a set of gsr cams and stock cam gears for sale. Taking offers, not sure if i want to sell or not, so make me a worthwhile offer
--And skunk2 dual valve springs and titanium retainers for a b16. can throw in stock valves too if wanted.used >10k miles.retails for ~400.
***$200***
--TiAL 50mm bov-polished, used, does not include flange. in great shape.
***$150***
--60mm wastegate-HKS GT2 style- ya it's an ebay wastegate but looks dead nuts on the GT2, it's anodized purple and looks good. they go for $150ish shipped on ebay. this one is used but is proven to work so there is no risk. has made 560+whp on a mustang dyno. connect to mani via vban- can include flange, and dump tube is vband-no flange tho.
***$100***
obd1 ls distributer, polished and can include brand new (still in box) rotor for it.
***$60***
FOR PICTURES CLICK THE LINK
http://www.imagestation.com/al...08469
If you need pictures of anything else just lmk and i can get them asap...I'll try to find a site where i can post them directly on here, but in the mean time, that link is the best i have.
***PM IS KEY***
includes:
-RC 440cc injectors
***$1700***
***$175***
***$20***
***$100***
***$200***
***$150***
***$100***
***$60***
CivicVX94
Southeast (Sales)
Jul 24, 2007 02:56 PM
