Need Help!! My civic wont start.. no dash lights, fuel pump doesnt prime, headlights work
Old Jul 22, 2007 | 05:51 PM
Miss PSI's Avatar
Default Need Help!! My civic wont start.. no dash lights, fuel pump doesnt prime, headlights work
I need some help diagnosing my problem. I think there's an issue with either my turbo timer or ignition switch. Wondering if anyone has had this problem before and can help.
When you try to turn the car over, no dash lights, no cranking, no fuel pump, nothing...
Checked the ECU and it isnt getting power, but the headlights turn on and the battery is good.
Info: 92 Honda Civic with GSR turbo
Update: I'm blowing the 50A Ignition Fuse... I'm getting small bit of smoke from the engine bay by the firewall on the drivers side. I guess theres a short.
Trying to figure out which is my most probably culprit.
Modified by Miss PSI at 9:11 PM 7/22/2007
Ef Hatch 34
Nov 14, 2011 08:41 AM
boarding2008
Apr 30, 2011 09:24 PM
A_Vigor
Acura TL, RL & ZDX
Mar 16, 2008 04:24 PM
Stray
Jul 14, 2007 08:30 PM
rtiadnoh
Jun 30, 2004 12:44 AM
