Torque sequence for the ITR head?
The follwing numbers represent head bolts when viewed from above. The bottom numbers represent the head bolts closest to the front bumper. This is the tightening sequence that should be followed.
9 5 1 3 7
8 4 2 6 10
-kenji
9 5 1 3 7
8 4 2 6 10
-kenji
I am changing the head gasket and I need to know the torque sequence for the ITR head. How should I remove and reinstall it? Thanks.
-Dave, who is not trying to be offensive but...
The first thing you should, if you want to do the job yourself, is buy the Helm manual. Then you will have all the information you need to do the job. It is not as easy as removing 8 bolts in the right sequence.
I do it differently, but I guess everyone has different approaches on things.
7 3 1 5 9
8 4 2 6 10
remember, 63 ft/lb.
also, be sure to torque the cam rail bolts to 20 ft/lbs. also, using the same torque method as mentioned above. those are the 12mm ones. the 10mm ones, just tighten them as tight as you would do the valve cover nuts. 20 ft/lbs. on those, and you'll be using an extractor to remove the threads from the head. LOL.
7 3 1 5 9
8 4 2 6 10
remember, 63 ft/lb.
