car shakes when letting out clutch in first gear....
my clutch pedal felt kinda light like there was no resistance so i bled the line and now thats what it does....its more of a really harsh shake rather than the wheels hopping...and now it sounds like there is like a whinning noise coming from the slave cylinder...and it goes away when i depress the clutch....i dunno if i somehow let air back into the lines and if that would make that happen but if anyone has any input i would appreciate it...Thanks
well i recently purchased the car and the clutch was replaced 5000 miles ago...it looks like the master cylinder was replaced too...but not the slave cylinder...its a 1995 gsr with 109000 miles...other than just bleeding the lines i have made no other changes...
The guy said its an oem....he had it professionally installed....i have a feeling that i bled the lines wrong and ended up getting more air trapped in there....because everything was working fine before hand....just the clutch peadl felt a little loose or whatever....but ill try bleeding the line again and see what happens...thanks for trying to help me out...
slic
Nov 16, 2005 04:40 PM
