how can i tell if my Fuel pump is going bad???
Old Jul 22, 2007 | 02:40 PM
jetoutant's Avatar
Default how can i tell if my Fuel pump is going bad???
Ok I have a 89 Honda Civic Si I think my fuel pump might be bad. Every time I go to start my car it runs for about 5 minutes then idles rough for about 1 minute and then stalls. When I go to try to start it again the main relay under the dash by the fuse box clicks rapidly and the engine light flash along with it. Could my pump be shorting out or about to go out completely.
Old Jul 22, 2007 | 03:28 PM
hatchling37's Avatar
Default Re: how can i tell if my Fuel pump is going bad??? (jetoutant)
Possibly, what codes is it throwing? Your stalling could just be gummed up fuel filter, fouled plugs, rotor/cap issues, or a bad ground or something getting knocked around after driving for a couple of minutes.
Old Jul 22, 2007 | 04:58 PM
jetoutant's Avatar
Default Re: how can i tell if my Fuel pump is going bad??? (hatchling37)
it dies before i can drive away and there is no codes
Old Jul 22, 2007 | 07:47 PM
Suck my DX's Avatar
sometimes when fuel pumps go bad, they overheat and give similar symptons to what your experiencing
Old Jul 22, 2007 | 07:54 PM
phootbag's Avatar
Default Re: how can i tell if my Fuel pump is going bad??? (Suck my DX)
I recommend performing a voltage drop at the main relay as the symptom occurs. Sounds like it might be failing.
Old Jul 22, 2007 | 08:05 PM
Leef9turbo
Guest
Posts: n/a
first of all a main relay can't fail going down the road.i would check the ground strap that bolted to the thermostat housing. my guess is that bolt is loose(any coolant system lately /engine swap)
ghettoda9
Apr 13, 2011 10:03 AM
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
go4wheeling
Sep 18, 2006 03:43 AM
Heavy Pee
Nov 22, 2003 08:01 AM
Agent Daimon
Feb 9, 2003 01:06 PM
