glass sunroof/moonroof
Sup,
I have a 90 honda crx si with a metal sunroof(hello rust). I ran across a 91 civic si the other day and it had a glass sunroof that went back into the car as opposed to mine which as u know goes back and on top of the car. Is there any way to get a glass sunroof to fit on .(90 crx si)? If so what years and what type of bracket changing do i have to do ?
John
John
howdy! 88-91 all fit eachother, when you take the headliner out you will see very clearly that there is a large black metal bracket that houses the sunroof(its like ten 10mm bolts that hold it in) take out all of the 10mm and the sunroof will just drop out and you can switch them! They are set up like this for the wet channal that drains from the sunroof.... goodluck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black_krix_si »</TD></TR><TR><TD CLASS="quote">A civic Hatch sunroof will NOT work. They do not switch over, not even close.</TD></TR></TABLE>
Correct.
Correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchMo »</TD></TR><TR><TD CLASS="quote">
Correct.</TD></TR></TABLE>
This topic has been covered too many times. Please search next time.
shyxboy
Dec 16, 2005 07:36 AM
justinau
Mar 14, 2005 02:41 PM
