Axle Question(SiR-II in EK)
Old Jul 22, 2007 | 11:58 AM
likenother's Avatar
Default Axle Question(SiR-II in EK)
I have a JDM B16a SiR-II swap from Hmotorsonline in my 96 EX Coupe. I have an axle going bad and I need to know which axle I need to get. I used the axles that I recieved from Hmotorsonline when I got the swap, which I am PRETTY SURE are Del Sol DOHC VTEC axles, but i'm not 100%. Does anyone know if 99-00 Civic Si axles will work with this, or do I need to find Del Sol axles to make this work? Thanks in Advance.
Old Jul 22, 2007 | 12:25 PM
Boosted4life's Avatar
Default Re: Axle Question(SiR-II in EK) (likenother)
yea 99-00 would work and 92-97 del sol also. Maybe other b series if you change the halfshaft.
Old Jul 22, 2007 | 12:34 PM
egsleepercivic's Avatar
94-01 tegs , 93-97 del sol DOHC vtec, and 99-00 SI, are all the same, if your car is non-abs you can use abs or non abs axles. if your car is abs you have to use abs axles,
gl
bratch
Oct 6, 2008 10:56 AM
justinrl613
Mar 14, 2008 12:08 PM
5spdIntegra
Oct 17, 2006 09:51 AM
OVA
Mar 19, 2005 09:00 AM
Kamin
Jan 22, 2002 11:01 AM
