headlight on passenger side, no power
Old Jul 22, 2007 | 11:00 AM
david542's Avatar
Default headlight on passenger side, no power
The high beem has no pwer to plug, on low beem there is power to plug but light won't come on. There two lights for this, one for high beem and low beem. The left does work. I'm having this car inspected on fri so I would like to get this fix before then. any help will be appreciated.
Old Jul 23, 2007 | 12:23 AM
Mista Bone's Avatar
D Tranny Guru
check both fuses and the ground box on the passenger side fender
Old Jul 23, 2007 | 12:25 AM
roycivic92's Avatar
Default Re: (Mista Bone)
LOW ON BLINKER FLUID ,JUST KIDING.
Old Jul 23, 2007 | 04:23 PM
david542's Avatar
this is just on the passenger side only that doesn't work. I turned the turn signal on to the right, the turn signal works, but no lights. turn the signal on with the light the signal, and light doesn't work, turn light to parking and the signal works again. so i'm wondering if it is my switch. no mater what i try i still have no lights on the passenger side. Thank you
Old Jul 23, 2007 | 04:36 PM
George Knighton's Avatar
H-T Order of Merit
Default Re: (roycivic92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roycivic92 &raquo;</TD></TR><TR><TD CLASS="quote">LOW ON BLINKER FLUID ,JUST KIDING.</TD></TR></TABLE>
You are banned!
Just kidding!
Old Jul 31, 2007 | 05:08 PM
david542's Avatar
I put in another headlight switch, and it worked for a little bit, the it when out again. I did take notice that when I turn the switch on the blower for the heater will cut out, until the switch is off. I would like to know if anyone had this problem before, what caused it, and what was done to fix it. Please will someone help me in fixing this. Thank you
GermyLin
Oct 8, 2018 10:17 AM
amit_b82
10
Mar 2, 2008 08:39 PM
Threads
Jul 31, 2005 06:58 PM
sik_sol
Mar 31, 2005 04:15 PM
