put an LS swap in my crx but it wont start
Old Jul 22, 2007 | 09:51 AM
crxlex's Avatar
Default put an LS swap in my crx but it wont start
when i go to start it it cranks up but it wont start like theres no fuel getting 2 it. i got it wired obd1 so i dont know if it could be a problem with the wirring or some thing else like the fuel pump
Old Jan 23, 2008 | 04:02 PM
nelsonb16's Avatar
Default Re: put an LS swap in my crx but it wont start (crxlex)
Have ever fix it if so hit me up because i did the same obd1 motor swap on my crx and it wont start.
Old Jan 23, 2008 | 04:45 PM
intense4thgen's Avatar
Default Re: put an LS swap in my crx but it wont start (nelsonb16)
maybe a list of parts you swaped out to convert to obd-1. what harness you using, did you make a clip down or buy one, are you getting any codes.
Old Jan 23, 2008 | 07:28 PM
nelsonb16's Avatar
Default Re: put an LS swap in my crx but it wont start (intense4thgen)
I'm using a obd o harness and i'm getting a code 15, I also have no spark.The only thing i rewired was the connecter on the dizzy so it can fit the obd 1 dizzy. Becaue its a obd 1 ls motor.
Old Jan 23, 2008 | 08:31 PM
CornerCarvin's Avatar
as far as no spark goes I did the same swap in a 90 SI hatch and the motor was straight out of my running 93 Teg. I had a few dizzy problems before I finally got it running. I put a new igniter in it and it fired right up. just one place to check.
Old Jan 24, 2008 | 07:22 AM
nelsonb16's Avatar
Default Re: put an LS swap in my crx but it wont start (CornerCarvin)
Thanks but i have one question at first when u finished the swap did start cranking at first, or did u get not even a crank. The reason being is as soon as i fished my swap it didn't even want to crank over or anything, so i put a bigger ground on the back of the block and then started cranking but no start also no spark and throwing a code 15 [ignition output singal]. An the only thing i rewired was the dizzy connectors.
boxerdogguy
Sep 21, 2015 02:42 PM
tyvtec23
Oct 20, 2011 04:11 PM
crazydude107
Aug 24, 2008 02:43 AM
vu337
20
Nov 15, 2005 12:37 PM
EGHatchy
Jul 11, 2002 11:24 AM
