4ws?
ok i was looking in the helms manual and seen the 90-93 edm accord came with 4ws.
I searched and can't find much info.
I have a 88 Si 4ws parts car, i'm wondering if anyone know If this would work.
I see the 94+ accord and use the 92+ prelude rear rack.
If any one has any info that would be great.
The only thing i found saying no, is about there not being enough room in the exhaust channel. ( cutting and welding not a problem!)
see if the rear subframe and trailing arms will bolt up. If they are somewhat close, then modify the holes to get it to bolt up. Plumbing is usuially the easiest part. As for the exhaust, all you need to do is cut the mid pipe and run a turn down.
BoostedH23Accord
Dec 4, 2008 05:30 AM
piggiepigg
Mar 5, 2006 10:09 AM
a1320honda
28
Jan 27, 2005 02:56 PM
