piston CR question, will it be the same in a different motor?
Old Jul 22, 2007 | 12:34 AM
blinx9900's Avatar
Default piston CR question, will it be the same in a different motor?
ok, if i have a set of 9.3:1 pistons made for an integra LS block, would it have the same compression in a b16a block? im assuming rod length plays a roll here, if its gonna be different anybody know what it would end up being?
im asking cause i have a buddy with pistons for a ls block hes not gonna use and i need a set. thank you.
Old Jul 22, 2007 | 08:28 PM
blinx9900's Avatar
Default Re: piston CR question, will it be the same in a different motor? (blinx9900)
up, please help!
Old Jul 22, 2007 | 08:39 PM
GSaura's Avatar
Here's a compression ratio calculator. http://www.c-speedracing.com/h...c.php
Old Jul 22, 2007 | 10:22 PM
blinx9900's Avatar
Default Re: piston CR question, will it be the same in a different motor? (GSaura)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSaura &raquo;</TD></TR><TR><TD CLASS="quote">Here's a compression ratio calculator. http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
thanks but that dosent help.
hybrid92b20
12
Feb 4, 2005 07:52 AM
super_slow
Feb 19, 2004 01:52 PM
one.simple.da
Jan 26, 2004 07:00 PM
Evil_Wizard
13
Nov 10, 2003 09:14 AM
