Make-up of Part Numbers
Old Jul 21, 2007 | 11:16 PM
NOFX's Avatar
H-T White Ops
Default Make-up of Part Numbers
I recently saw a post asking what different characters in a part number mean. Do they refer to a year, body style or what?
So here is what I found out about at least some Honda part numbers.
I'll be using some old part numbers for this since it's what I have laid out as an example from Honda.
All part numbers are classified into two groups consisting of "GENERAL PARTS" and "STANDARD PARTS". All parts are numbered in accordance with the system described below.
IMAGES ARE NOW AT BOTTOM OF POST/SAVED ON H-T.
New wrenches in the 5.5mm, 7mm, 12mm, 22mm, 24mm and 27mm sizes will be required for the modified bolts and nuts. All other sizes are currently in used.
This change in Hex affects only the wrench sizes: Interchangeability of bolts and nuts are not affected.
ALL NUTS: There will be a hemispherical dimple on EITHER THE TOP OR SIDE of the nut in all sizes with changed pitch. This will also apply to nuts that are permanently welded to other parts.
All mechanics and parts department personnel should read and understand this change-over, to avoid confusion and damage to threaded parts.
** Info all from the Honda Z600 Coupe / Honda N600 Sedan Parts Catalog
(c) American Honda Motor Co., Inc. 1986
Old Jul 23, 2007 | 02:54 PM
ToeJam's Avatar
Default Re: Make-up of Part Numbers (NOFX)
Thank You
Old Jun 21, 2010 | 07:10 PM
NOFX's Avatar
H-T White Ops
BUMP
Old Aug 24, 2011 | 11:34 AM
apwhat's Avatar
awesome bit of information, thanks man!
Old Aug 24, 2011 | 11:46 AM
grumblemarc's Avatar
The Grumpiest
You mean thanks WOman.
Old Aug 25, 2011 | 10:38 AM
NOFX's Avatar
H-T White Ops
Glad to help. Never thought anyone ever checks out this thread!
Old Nov 18, 2013 | 01:42 PM
NOFX's Avatar
H-T White Ops
Sorry for giant images. On a phone and couldn't resize them. But at least all the info is back up.
85ascMcLaren
Nov 10, 2013 10:05 AM
raverx3m
Sep 19, 2010 03:56 PM
vinuneuro
Feb 24, 2007 03:55 PM
turboex
Feb 20, 2002 03:12 AM
