battery light wont turn off
1995 civic dx d15b7 all stock
i started the car and the battery light wouldnt turn off
i checked the voltage at the battery with the car running 13.54-13.67
battery with the car running headlights on 13.11-13.23
turn the headlights off back at 13.54-13.67
same voltage directly at the alternator with the car running.
car off at the battery was 14.56 held the same voltage for a couple minutes while i had the meter on it
so i think its safe to drive...so we hop in and go to target about halfway there i put the blinker on it and the speedo bounces from 70 down to 0 the same as the blinker does...the gauges dim down...rev it up to about 5k and its good all the way to target and i check the voltages back at target and it was all the same...made it home with no problems at all
any suggestions?
this is a retarded problem to have
:edit: battery terminals were tight and not coroded
so it seems as if the charging system is working great
any suggestions?
Make sure your alternator harness is plugged in first of all, as a precaution.
I would remove the alternator and have it load tested. Even though the alternator puts out the required voltage, the amperage may be way out of spec. This is caused by a failed diode(s) in the alternator, and can come along with a very annoying whining sound.
The stator has 3 (sometimes 4) feed wires to the battery, coupled into a WHT or WHT/RED wire to the battery, because of the rotation of the armature/stator. If one of them failed, it will still make the 13.8v required, but with much less current. If the voltage regulator fails, your voltage will fall, hence the name voltage regulator.
ONE*SICK*FERIO
Oct 12, 2009 06:03 PM
