Dual point to multi-point swap
i did this swap a long time ago. i also had the same problem as you. Did you double check everything to make sure you had all the wires in the same spot? I found out that i mixed the 2 blue wires and the 2 white ones at the dizzy around .
how many check engine lights do you have.
If your light is on and you haven't checked it, don't reply with "It's on but I don't know what they are"
If it's not on, then it's harder to diagnose.
If it is on, find out what code(s) it's throwing and get back to us.
You sure you have the right connector hooked the the IAT?
The IAT and EACV are interchangeable I think. (It's either that or IAT and TPS...I had mine mixed up when I converted to MPFI.) Meaning they'll both plug into each other...try swapping them and check for codes again.
SeanWard
Apr 2, 2009 07:01 AM
dohdoh420
Jul 20, 2007 08:54 PM
