Need your Advice on Radiator Leak.
Old Jul 21, 2007 | 07:02 PM
goota's Avatar
Default Need your Advice on Radiator Leak.
So a little background. Im from Socal, but I got a job here in Phoenix, AZ. and Its HOT as a ***** here, My Radiator fluid is always lows, I dont necessarily leak radiator fluid on the ground. But I think that I have a crack on the top of my radiator so I think in this 100+ degree weather (24 hours a day) that the fluid is just evaporating through the crack, thus no leaks on the ground ever. Anyways this is the leak.
I am thinking of cleaning it and putting some JB weld on there to fix it. I basically made this post to see if any of you have had experience with doing something like this and it totally backfiring on you. Really I just want certification that this would be okay to do. Just checking all my bases you know?
Thanks in advance for any replies.
Old Jul 21, 2007 | 07:40 PM
ekb16's Avatar
y not just replace it
Old Jul 21, 2007 | 08:09 PM
goota's Avatar
Old Jul 22, 2007 | 12:09 AM
Flashmn's Avatar
Default Re: (goota)
Engine overhaul due to heat damage = more $$$$ than the radiator.
Old Jul 22, 2007 | 02:50 PM
postman's Avatar
Default Re: (Flashmn)
your core is leaking by the endtanks. jb weld will never hold it. if it does it will only be a short amount of time.
Old Jul 22, 2007 | 03:24 PM
hatchling37's Avatar
Default Re: (postman)
Put some Barsleak in that bitch! No, but seriously, you should be able to find a new radiator for around a hundred bucks. You should definitely attempt to throw a new one in.
Old Jul 22, 2007 | 03:33 PM
GSaura's Avatar
Default Re: (hatchling37)
It looks like there's a hole in the upper tank right where the gap in the bracket is. You have nothing to lose by JB welding it and keeping an eye on the temps. If it works it works, and if it doesn't you have to buy a new radiator.
Old Jul 22, 2007 | 04:13 PM
goota's Avatar
Thanks for the replies guys. Im going to JB weld it right now, and buy a new radiator once i get my paycheck on friday.
Any suggestions on where to buy a radiator?
Old Jul 22, 2007 | 05:05 PM
biggmike2's Avatar
Default Re: Need your Advice on Radiator Leak. (goota)
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Jul 22, 2007 | 05:18 PM
Hybrid96EK's Avatar
Default Re: (goota)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goota &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the replies guys. Im going to JB weld it right now, and buy a new radiator once i get my paycheck on friday.
Any suggestions on where to buy a radiator?</TD></TR></TABLE>
I have a 95 GSR manual radiator in my garage right now. No use for it. Make me an offer.
Old Jul 23, 2007 | 08:22 PM
goota's Avatar
Default Re: (Hybrid96EK)
Thanks for the offer but I think I am going to get a Mishimoto radiator.
anyways the JB weld is holding up so far, just FYI, should be ordering a radiator by tmrw.
BB4lude
18
Mar 10, 2008 05:10 PM
tommyt761
Oct 12, 2006 01:00 PM
vtecmw
Dec 5, 2005 09:44 AM
Chip398193
Nov 1, 2003 10:01 PM
scrubachu
Feb 6, 2003 01:32 PM
