EP3 Hybrid Question
Old Jul 21, 2007 | 06:51 PM
crxhybrid85's Avatar
Default EP3 Hybrid Question
With a lot of states now doing emissions testing by verifying there are no OBD2 trouble codes it is very hard to modify an 96+ car.
I like the EP3's and would kinda like to pick one up but do type s motor or maybe a 2.4L hybrid of some sort. Can a swap be done like that and still have the OBD2 diagnostic port functioning so it can pass inspection?
Old Jul 22, 2007 | 11:08 AM
tsr_75th's Avatar
lots of EP owners do Type S swaps. You shouldn't have a problem passing emissions as long as you retain the stock emission components.
Old Jul 22, 2007 | 11:55 AM
Default Re: (tsr_75th)
I suppose that any K motor would probably work then if you used the ECU for that engine. What about a frank motor with a k24 block and a type s head that you would have to run with K pro? Does K pro retain the OBD2 diagnostic port?
Old Jul 22, 2007 | 02:29 PM
WhiteOnRice's Avatar
It should since it's still the OEM ECU.
Old Jul 27, 2007 | 03:35 AM
CubanoRockr's Avatar
Default Re: (WhiteOnRice)
witht the k-pro ecu it would give you the codes it would work just as stock, but if you nneded to pass emissions you'd just have to get it tuned to be close to what the factory ecu does off throttle at cruising speed
dc4teggiehatch
Sep 10, 2021 02:55 PM
littlej72
Mar 13, 2008 02:08 PM
tc_gts
Oct 28, 2007 12:22 PM
Ti3d in
May 8, 2004 07:06 PM
