TODA B's with stock redline??
Old Jun 9, 2002 | 11:25 PM
Type-Rare#1248's Avatar
Default TODA B's with stock redline??
yes yes...i know...Toda B's make best power at around 9 G's...but I dont wanna bother with upgrading spring blah blah blah...injectors, replacing timing belt all the time and lessening the reliability of a type R
I originally planned on keeping stock cams but I heard the B's have awesome midrange.. I wonder how well they perform with not too much engine work...I am considering bumping up the compression, and tuning it with cam gears and VAFC
I hope to get some advice and ppl to speculate on the power it would make
thanx
Old Jun 9, 2002 | 11:35 PM
01PYITR's Avatar
Default Re: TODA B's with stock redline?? (Type-Rare#1248)
Thats not a half bad question, and as for cost is it worth it ?
Old Jun 9, 2002 | 11:37 PM
Hybrid ctr's Avatar
Get Toda A's instead, they make good power.
Old Jun 9, 2002 | 11:38 PM
Default Re: TODA B's with stock redline?? (Hybrid ctr)
I know but I heard Toda B's have better midrange?
Old Jun 9, 2002 | 11:42 PM
mafay2's Avatar
New User
IF you want to do a half *** job with the Spec B, you will probably be very dissapointed with the results that you get for the money you spend on the cams. If you want stock redline and stock everything, just go with Spec A. If you get the spec B, at least get the Toda valve spring, a good header exhaust combo, and at least a chipped ECU.
Old Jun 9, 2002 | 11:53 PM
Default Re: TODA B's with stock redline?? (mafay2)
i plan to increase compression and tune...just not raise redline...I think thats reasonable...ppl dont get much power normally cuz they just drop the cams in
Old Jun 10, 2002 | 12:01 AM
Hybrid ctr's Avatar
I suggest you do some more research.
The search is your friend
Old Jun 10, 2002 | 12:19 AM
i searched...this is a relatively new idea
Old Jun 10, 2002 | 12:30 AM
mafay2's Avatar
New User
If you plan to rise the compression and tune, why not get the Toda spring and PE timing belt as well? You will have your engine apart anyways.
It is the huge primary lobe that make the stock timing belt break, so I don't think higher redline have too much to do with it. Also, a higher redline will be come in handy when you need it, like in the race. But that doesn't mean you have to rev to 9500rpm all day even if you have a high redline.
Old Jun 10, 2002 | 02:16 AM
MooFX's Avatar
higher redline =
it sounds beautiful when it's up at 9700rpm
just like mafay2 said, you dont have to rev up that high all the time, only do it when you race
[Modified by MooFX, 11:17 AM 6/10/2002]
Old Jun 10, 2002 | 04:09 AM
sgT's Avatar
sgT
Default Re: TODA B's with stock redline?? (MooFX)
Spec B is fine up to stock redline since it doesnt make more power past 9000
anyway. Just make sure you use toda valvesprings.
Old Jun 10, 2002 | 04:36 AM
B18CXr's Avatar
B's in a stock C5 will not make power past 8200.
Old Jun 10, 2002 | 06:02 AM
Black R's Avatar
25 Year Member
Default Re: TODA B's with stock redline?? (B18CXr)
.....with stock compression and toda header, my spec b's made whp all the way to 8600. tp starts to fall off after that though...
Old Jun 10, 2002 | 06:10 AM
Pinhead's Avatar
New User
Default Re: TODA B's with stock redline?? (Black R)
yea, you should be fine...just get toda Valvesprings, a descent header exhaust combo, and a PE belt
Old Jun 10, 2002 | 06:25 AM
Rob :190:'s Avatar
Default Re: TODA B's with stock redline?? (Pinhead)
talk to ITR009, he ran B's with stock stuff.
Old Jun 10, 2002 | 10:03 AM
Default Re: TODA B's with stock redline?? ( Rob)
thx for the reply everyone
if i changed the valve spring, would i have to change retainers as well?
[Modified by Type-Rare#1248, 12:07 PM 6/10/2002]
Old Jun 10, 2002 | 10:11 AM
r7's Avatar
r7
whats a PE belt ? , never mind just found out! power enterprise, whats a good price for one ?
[Modified by r7, 7:13 PM 6/10/2002]
Old Jun 10, 2002 | 10:29 AM
Splat's Avatar
Collector-o-Guns and Drinker
Yep. I'll respond here instead of replying to your IM...
My setup = Toda Spec B cams, Toda 1st gen cam gears, AEM CAI, JDM 4-1 header + 2.5" Jeg's cat with modified ITR b-pipe and stock can. V-AFC for fuel correction, Yack-tuned. Stock rev limiter, stock FP, stock valvetrain.
Reasoning = Got a deal too good to pass up on the cams, but could not afford the extra goodies at the time. So Yack just slapped in the cams and roughed in a state of tune. Then he dyno-tuned it a few months later. Went back to initial tune (cam gears zero'd out and necessary fuel corrections) to pass emissions.
Verdict = As long as you pay attention to the things that need attention, you'll be fine. I probably made about 180-183 peak whp, along with that big nasty Toda B midrange. Stay off the rev limiter, check your valves fairly often. Realize that you aren't making the full potential of these cams with stock compression, vtrain, etc. But if you're on a budget, start small and work your way up. I was pricing a valvetrain, but ended up deciding to sell the car, so the cams were yanked.
My car, doing third-gear pulls and such, hung with another B-equipped R with valvetrain and other goodies. It was a good bit faster than stock, but by no means the fastest we-todd-driven B18C5-powered car around.
If I did it over again - I'd go all-out. But that takes money
But you can build a daily-drivable, reliable, non-breaking Toda B-equipped car using many stock parts. Just don't try it with the stock airbox and exhaust manifold. You'll lose 15-20 horsepower and generally hate yourself.
Old Jun 10, 2002 | 10:32 AM
tecnic1's Avatar
https://honda-tech.com/zerothread?id=192712 this about sums it up. IMO don't dic around with toda bs unless your are ready to to get springs, retainers, header, ECU, and injectors. You say your going to bump compression as if it's like installing an intake. If your worried about changeing retainers, bumping compression is much harder to do right.
Old Jun 10, 2002 | 10:39 AM
RStoR's Avatar
Just to let those know what can be had. Stock compression,valvetrain, ecu(+ vafc).
[Modified by RStoR, 2:40 PM 6/10/2002]
Old Jun 10, 2002 | 10:45 AM
Rob :190:'s Avatar
Default Re: TODA B's with stock redline?? (RStoR)
chris, you get my email about the st00k antenner?
Old Jun 10, 2002 | 10:49 AM
Default Re: TODA B's with stock redline?? (itr009)
thx everyone who replied
ITR009, that was great help
Old Jun 10, 2002 | 10:51 AM
Splat's Avatar
No problem. Just want to dispel some misinformation that's out there.
Can you do it? Yes.
Is it *as safe* as adding vtrain? Maybe not.
Will you make the most power? No.
But it can be done, and you will enjoy the extra power
Old Jun 10, 2002 | 10:54 AM
Back in Black's Avatar
Rather OG
Most of the 15-20 hp loss you spoke of can be attributed to the stock exhaust system choking the setup. I lost just 2 peak whp, while improving the midrange when going back to the stock airbox. The AEM does sound nice though, and adds some decent bling-bling factor
Old Jun 10, 2002 | 11:00 AM
Johnny Tran's Avatar
Default Re: TODA B's with stock redline?? (Jason Franza)
especially when you get it chrome plated with gold plated "aem" on the side like jason
