4.9 final help
Old Jul 21, 2007 | 05:37 PM
turboITR#704's Avatar
Default 4.9 final help
What is needed to swap out the 4.4 final with the 4.9 final drive thanks
Old Jul 21, 2007 | 05:51 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: 4.9 final help (turboITR#704)
a 4.9 final drive, mechanical skills, required tools, and a 6 pack of favorite beer
Old Jul 22, 2007 | 09:30 AM
Default Re: 4.9 final help (JJSpecTuning)
I have the trans apart and the final is in went to put main and countershaft in and the lower gear on the countershaft will not mesh with the final drive gear what am I doing wrong
Old Jul 22, 2007 | 09:40 AM
slowcivic2k's Avatar
If you are using a 4.929 FD you also need the corresponding countershaft from ATS, if its a JDM transmission you will not need the first gear, but if your transmission is USDM, you will need the distance collar, needle bearings, and the right size 1st gear as well from ATS.
Old Jul 22, 2007 | 10:31 AM
Default Re: 4.9 final help (slowcivic2k)
Im guessing that its from ATS because the L.S.D that it was attached to is not o.e.m honda This was given to me by a friend that does not know to much about hondas the person that gave it to him said it was all O.E.M is there any distinctive marks to look for to determine for sure that its A.T.S thankyou
chriss sheppard
Honda Civic (2006 - 2015)
Nov 22, 2007 02:11 PM
thorshammer56
Honda Motorcycles
Jun 6, 2007 08:05 AM
jdmcivicferio
Dec 5, 2006 09:14 PM
5zigen_dc5
Mar 31, 2006 05:06 PM
