DC5 brake setup
i'm lookin to get some serious brakes for my dc5 since i do alot of auto-x and will be doing a lot of trackdays in the future. Just wondering what people run as far as brake setups for racing purposes. I was thinking of getting ap racing brakes, does anyone have any suggestions??
Get a set of Cobalt Friction pads. The GTS pad will be great for auto-x and track use. If you are in need of a higher pad on street tires on track, then go with the XR3's.
-Victor
-Victor
thanks for all the info
ill start with pads, and i think i might do cryogenicly frozen slotted rotors also, my bro suggested them so i think i might get a set as well with a good set of pads
oo and has anyone used spoon pads before? are they any good??
I recommend CarboTech ... I've been running their pads on my EP3 for about 3 yrs now ... excellent modulation and stopping power! I'm currently running the 1108 compound (meant more for HPDE track days) ... you could get by using the Panther+ (1106) compound for AutoX events. They tend to make a good bit of noise until up to temp (this can be expected with any high performance pad), they do make considerable dust, but it's non-corrosive (so your paint and calipers will stay happy). Rotor life has been excellent ...
Prices are affordable ... and they usually run pad/rotor sales. Great customer service ...
If you are into racing, and have big wheels with agressive tires, I'm coming out with an RL retrofit. It uses the new Acura RL caliper, which uses an 8lb aluminum 4-piston caliper, a BIG *** pad, and either a 12.3" or a 12.6" rotor (I should have it prototyped within two weeks.) It will go for around a grand, which is a lot cheaper than three grand for a full aftermarket setup (and this gets to use blank rotors
yoorang
Feb 4, 2007 08:28 PM
