car no start
Old Jul 21, 2007 | 02:24 PM
Jago's Avatar
Default car no start
got a 93 integra gsr. motor was out all winter getting built. Car has spark compression no fuel pulled the return line and feed both are dry checked the pump it will not prime or run conector has power on one wire and im not seeing any switched voltage. I'm gessing main relay on this I will be bringing more electrical tools next time I go work on it. Anyone here got any other ideas or had any other similar problems. also anyone have wiring diagrams for this car. thanks
Old Jul 21, 2007 | 06:48 PM
phootbag's Avatar
Default Re: car no start (Jago)
The power wire for the fuel pump is the black/yellow wire. Do a voltage drop at the main relay.
Old Jul 21, 2007 | 07:26 PM
benjamin626's Avatar
Default Re: car no start (phootbag)
maybe you missed one of the ground wires?
Old Jul 22, 2007 | 07:54 AM
Jago's Avatar
Default Re: car no start (benjamin626)
i'll be taking a closer look at everything sometime this week.
Old Jul 22, 2007 | 08:27 AM
5_Lug_B's Avatar
* B A N N E D *
This may sound dumb but did you check the fuel pump fuse?
Old Jul 22, 2007 | 12:17 PM
Jago's Avatar
Default Re: car no start (5_Lug_B)
checked all the fuses all were good
Old Aug 2, 2007 | 02:21 PM
Jago's Avatar
main relay fixed it
raverx3m
Sep 16, 2011 11:09 PM
rymander
May 28, 2011 03:12 PM
The AW Alchemist
May 11, 2009 06:35 PM
pprowler6
Dec 26, 2005 09:53 AM
