Can i put install a high flow cat from a 96+ integra into my 95.
Old Jul 21, 2007 | 01:49 PM
immalooser's Avatar
Default Can i put install a high flow cat from a 96+ integra into my 95.
Hey guys,
I'm looking to by a Magnaflow direct fit high flow cat. The problem is taht its for a ODBII vehicle. My question is can i buy that cat and plug the other O2 Bung and use it on my 95 GSR?
Old Jul 21, 2007 | 04:26 PM
gsrious's Avatar
sure you can. as long as they are both the same length and have the flange at the right angles.
_______________________________________
to help you out more. the "direct fit high flow cat" that you are looking to buy has to be 17&5/8" in length. the car it is coming off of has to be a 94-99 gsr only.
the 96+ ls, type r & the 00-01 gsr have the donut flange at a different angle.
pm me if you need further advice.
Modified by gsrious at 9:11 PM 7/21/2007
Old Jul 21, 2007 | 06:32 PM
immalooser's Avatar
Default Re: (gsrious)
well i suppose my question is are the 96-99 gsr cats have the same length and flange as the 94-95 gsr's
Old Jul 21, 2007 | 07:25 PM
SuckMyDOHC's Avatar
should be the same size. you're just going to have to plug the bung for the o2 sensor
Old Jul 21, 2007 | 08:11 PM
gsrious's Avatar
Default Re: (immalooser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by immalooser &raquo;</TD></TR><TR><TD CLASS="quote">well i suppose my question is are the 96-99 gsr cats have the same length and flange as the 94-95 gsr's
</TD></TR></TABLE>yes, they are the same.
no2unenolife
Dec 16, 2006 01:24 AM
13HYBRID20
Apr 17, 2005 09:40 AM
ecks_fourttwo
Apr 14, 2005 11:13 AM
allshowallgo
May 18, 2004 02:16 PM
1.7na
Jan 16, 2004 01:08 PM
