Another Engine Swap Won't Start Problem!
Old Jul 21, 2007 | 12:21 PM
importdreamer's Avatar
Default Another Engine Swap Won't Start Problem!
We swapped a 96-00 SOHC non-vtec ZC into a 91 crx si. The problem is that the engine tries to turn over but won't stay started. It spins and sounds like the timing belt is snapped but it isn't. Pulled the spark plug and you could smell gas. There was a little bit of gas leaking from the fuel filter but we should be able to fix that by turning over the washers on each side. It is getting spark when we pulled the wires and you could hear em clicking.
Where the car is located there is no internet, so i was hoping to get some ideas before we head out there. Anyone got any thoughts?
Old Jul 21, 2007 | 12:49 PM
Default Re: Another Engine Swap Won't Start Problem! (importdreamer)
anyone?
Old Jul 21, 2007 | 01:03 PM
anyone know the gappage for the plugs on a 99 domani (that's what this engine came from)?
Old Jul 21, 2007 | 02:13 PM
about to head out any ideas?
Old Jul 21, 2007 | 06:12 PM
It spun and spun and spun every time we tried to start it. On a couple tries it actually popped in the intake piping. We also noticed small amounts of white smoke coming out that smelled like exhaust. Furthermore (no really that isn't enough) one of the NGK Iridium spark plugs ( that was properly gapped don't worry) seemed to be missing a portion of the diode. Not the curvey part but the little filament below that. Any thoughts on this?
Old Jul 22, 2007 | 11:30 AM
bump
SI-ICK
Mar 31, 2013 05:30 PM
gowenburnett
May 30, 2011 05:20 PM
EcivicG
20
Aug 11, 2008 06:09 PM
dra600n
23
May 30, 2007 05:52 PM
CWITR
May 3, 2005 04:38 PM
