Pressure Plate Bolts, are they universal?
Old Jul 21, 2007 | 11:35 AM
310HPS2k's Avatar
Default Pressure Plate Bolts, are they universal?
I broke the Bolt off on my pressue plate. I just had them take out at a machine shop.
I wanted to get the ARP set while i am at it and cant find any.
Do you guys know if the B series are the same? because ARP does have them for b series.
Also if not, where can i buy some stock ones
Thanks!
Old Jul 21, 2007 | 03:12 PM
xxmastermindxx's Avatar
Default Re: Pressure Plate Bolts, are they universal? (310HPS2k)
i can't answer for sure, but if it were me, i would assume that if they specify B series, they probably won't work for H series. Just an assumption though...
Get your stock bolts at the dealership.
Old Jul 22, 2007 | 03:54 PM
310HPS2k's Avatar
Well on my clutch when i took the tranny off I got these bolts
5 x 10mm 12 points bolts
1 x 12mm 6 points bolts
WHen i called honda they say that they had 8mm 12 point bolts for the H motor. they double checked and they were the same for the F motor.
Should I changed all mines over to what the dealership says?
Old Jul 22, 2007 | 04:26 PM
Hawkze_2.3's Avatar
Default Re: (310HPS2k)
H and F engines (except F20C, F22C from the S2000) have the same block and use the same parts. Just order some from the dealer or you can use http://slhondaparts.com or http://hondaautomotiveparts.com.
Old Jul 22, 2007 | 08:12 PM
310HPS2k's Avatar
I have checked those.
Do you guys have any clue what you guys have on your clutch?
raidacaipo
10
May 7, 2009 12:51 AM
Nick97hatch
Transmission & Drivetrain
Feb 3, 2009 07:22 PM
RobbieG35
Jul 12, 2006 09:41 AM
lazynok
Jan 9, 2005 05:59 PM
elmalouno
May 24, 2004 07:48 PM
