Trying to find the right size slick
For anyone Running a slick at the track what size are you running? Don't want serious rubbing or it to be to low. I have some weld 3.5 pro stars sitting in my room going to see if the bolt pattern is the same im 90% sure it is
And what rims you guys using for the track in the fronts? I was looking at the weld honey comb style but alot of people I see are using reg street style 15" rims
any help Is Apreciated
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pampass_pmw »</TD></TR><TR><TD CLASS="quote">If you are at stock ride height I would think that 22x8-15 would fit well and the growth would not rub.</TD></TR></TABLE>
i thought 15's wouldn't clear the brake caliper's on si's
I don't know thw answer to that but you will be hard pressed to find a true slick that has a rim size bigger than a 16, there are some 17 but they are way too big to fit on a civic.
Now if you want to run drag radials then you find other sizes.
2003TurboSi
Jun 3, 2004 07:33 AM
