Code #20, Electric load detector .. is it something to worry about?
ECU is P28 . (crome)
i had this CEL but it doesn't light up .. only time it shows up is if i loop the service
connetor.
it's electric load detector.. is it something to worry about? how can i get rid of it?
i had code #22 and it's now gone after i reset the ECU.
any comments would be appreciated
connetor.
It is an option that can be disabled in Hondata. It is not really necessary from what I researched. It is built into the under hood fuse box, so if you wanted to fix it, you would need to replace the whole fuse box.
0ne-Cam
14
Aug 20, 2009 06:58 PM
