Check engine light on and vtec not engaging
Old Jul 20, 2007 | 03:52 PM
narraticon's Avatar
Default Check engine light on and vtec not engaging
Check engine light is on and the vtec does not feel like its engaging. Looks like codes 21 and 23 how do i go about fixing this problem myself or leave it to the honda specialists.The engine is a b16 swaped into a 91 honda civic.
Old Jul 20, 2007 | 05:39 PM
boostedblkef's Avatar
Default Re: Check engine light on and vtec not engaging (narraticon)
vtec isnt working cause your prob running in "limp mode"
are you running obd1 or non if obd1
code 21 is your vtec solenoid also why vtec isnt working
code 23 is knock sensor
hope i helped let me know if you need anymore help
Old Jul 20, 2007 | 05:41 PM
narraticon's Avatar
Default Re: Check engine light on and vtec not engaging (boostedblkef)
yes but I mean how do i go about fixing this .......or am i screwed
Old Jul 20, 2007 | 05:55 PM
more info is needed about your setup r u running a knock sensor still or was the ecu chiped and removed check your oil make sure the sol is wired correctly make sure knock is wired if using it many factors
Old Jul 20, 2007 | 07:17 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/zerothread/1812135
Civic plow
Mar 25, 2016 10:31 AM
91EF_Si
Sep 25, 2007 08:40 PM
92accordh22a
Dec 17, 2006 12:05 AM
CrisEK
13
Jun 12, 2005 02:48 AM
CrisEK
Jun 2, 2005 11:46 AM
