ECU pin????
Old Jul 20, 2007 | 01:45 PM
dumped4dr's Avatar
Default ECU pin????
First off, i've searched and am using this diagram http://www.mobstyle.com/crx/ecu_pinouts2.asp
Im trying to find the right wire to get a rpm reading. I have connected to both pins b15 and b17 and havent gotten anything out of them. am i using the wrong pin or is something else messed up?
thanks in advance!!!
Old Jul 20, 2007 | 03:12 PM
jlicrx's Avatar
Default Re: ECU pin???? (dumped4dr)
the tach signal comes from the blue wire at the 2-wire connector at the distributor - the blue wire ends up at the gauge cluster, not the ECU
Old Jul 20, 2007 | 03:17 PM
dkrex001's Avatar
ok for a rpm reading just go to the back of your gauge cluster
Zatzy
Mar 15, 2006 01:46 PM
Fugun
Nov 23, 2005 03:24 PM
pdcivic
14
Jun 25, 2003 09:26 PM
xXx Justin xXx
Jun 13, 2002 07:20 PM
Ray
Jun 23, 2001 07:21 PM
