Fuel injectors with toda Bs!!!
this is for a friend with a gsr.... "What type of injectors should i use for my toda B's? Will prelude injectors suffice and how much do they cost? Any butt-dyno gains from just dropping these in? How does this effect my smog? And will i have to re-dyno tune my car?" can you help him??
go with preludes. at high rpms. knocking is decreased with the preludes. s2000 injectors are too much. they richen idle too much. after the prelude install i found an adjustable fpr works better with prelude injectors. stock integra injectors are good enough if you dont tend to stay at the high rpm range
I run the prelude injectors but i get fuel starvation in my high rpms. so i think i need to go bigger to with a fpr. I get a lot of knock at high rpms still
[Modified by mugenintegra16, 7:56 AM 6/10/2002]
Casey
16
Feb 16, 2004 04:44 PM
