Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
01 crv with a bad cat will this work?
Old Jul 20, 2007 | 12:45 PM
djmota's Avatar
Default 01 crv with a bad cat will this work?
My girlfriend has a crv with a bad cat (cel p0420) its got about 120k miles on it and it looks like the cat failure is pretty common at that milage. Do you think a cat from my 01 civc could be welded in place and work fine. I took my cat off at around 12k miles so it practically new. it looks close to the same size but i have yet to measure it.
Old Jul 26, 2007 | 08:39 AM
justint's Avatar
Default Re: 01 crv with a bad cat will this work? (djmota)
It should work fine or go buy a generic CATCO or the like converter. At that mileage the 02 sensors are also probably due for a replacement.
Old Jul 27, 2007 | 10:32 AM
djmota's Avatar
Default Re: 01 crv with a bad cat will this work? (justint)
thanks . Its starting to show signs of a clogged cat. (motor vibration when accelerating poor acceleration) I'm going to pull the cat and take a look. if its clogging i think i'm just going to hollow it out and run an 02 sim for now. money is short. I'll check the plugs to see if its running rich or lean. I'm sure its due for a valve adjust. I guess thats about all i can do on the cheap for now. any other advice?
mrspeedy69
15
Jun 13, 2009 06:09 PM
djmota
Jul 20, 2007 02:40 PM
pbink
Aug 28, 2005 11:50 AM
sporkcrx
Oct 6, 2003 09:15 PM
