DOHC ZC what kind of Tranny
Here's your options:
ZC tranny
Civic/CRX Si tranny
Civic/CRX DX tranny
I would recommend the Si tranny for cost and ease of use. You can just use your stock axles.
I believe the ZC you have to use the ZC axles.
ZC tranny
Civic/CRX Si tranny
Civic/CRX DX tranny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REDBARON »</TD></TR><TR><TD CLASS="quote">Here's your options:
ZC tranny
Civic/CRX Si tranny
Civic/CRX DX tranny
I believe the ZC you have to use the ZC axles.</TD></TR></TABLE>
I also recommend the Si because you would also need a ZC intermediate shaft to run the ZC tranny. Another option is the Si/ZC hybrid, where you swap the ZC 5th gear into the Si trans.
ZC tranny
Civic/CRX Si tranny
Civic/CRX DX tranny
I'll probably stick with the Crx si tranny but does any company out there have an upgarded axle for them? and will a LSD for the l3 tranny work if its bolted up to a DOHC ZC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lowdreams »</TD></TR><TR><TD CLASS="quote">I'll probably stick with the Crx si tranny but does any company out there have an upgarded axle for them? and will a LSD for the l3 tranny work if its bolted up to a DOHC ZC
If you are able to run it in the CRX Si trans, I don't see why it woudln't work with the ZC motor.
