Taking dents outta DC fender...
Old Jul 20, 2007 | 10:36 AM
Byaaah!'s Avatar
Jet Life Til' The Next Life
Default Taking dents outta DC fender...
Driver side fender has no hope for it...
Passenger side does, somebody kicked it in, still has a beatiful fit, the dent is a little pushed in and fist sized, can I take it out, no point in buying a new one when this is an easy fit...
Old Jul 21, 2007 | 08:20 AM
gsl_05's Avatar
Default Re: Taking dents outta DC fender... (Project95LS-VTEC)
Yes, since you the fender off already, try using the underside of a spoon and slowly press out the dent. You can even heat it up a little bit, then press out. It will start to shape, if you have the patience. Sorry I don't have pics, but I have done this to a couple of USDM and JDM fender and you can 80-90 % of the dent out.
Old Jul 21, 2007 | 10:45 AM
Byaaah!'s Avatar
Default Re: Taking dents outta DC fender... (gsl_05)
Thanks a lot, that will save me $ so thanks...
I will keep you updated if you like...
Old Jul 22, 2007 | 06:04 PM
sc4dr's Avatar
It would be easier to fix the dent while the fender is on the car, so the fender won't move around on you. A trick to working out dents is to use florescent lighting to cast a shdow on the panel. A dent will make the reflection look bent, use a pointy object and slowly push out the dent from the outside in.
Old Jul 22, 2007 | 06:36 PM
Lost_clearance's Avatar
the fender has no structure so doing it on the car is a good idea, bur put a dolly spoon in behind it and his the high points of the dent working side to side (off doly) if you do it with the right force the dent will pop out
learned that in trade school
Old Jul 24, 2007 | 10:44 AM
doubleshotz's Avatar
if diy fails
buy new fenders
its cheaper than having a shop repair em
good luck
low_and_slow
Paint and Body
Mar 25, 2010 07:39 PM
i_VTEC
Sep 15, 2008 03:24 PM
RineRacing
Oct 30, 2001 06:52 AM
