95 EX Coupe.. is it obd-II?
i dont see a service connector but as the topic suggests i was wonderin if a 95 EX coupe would have obd-II ? I have a carputer setup thats goin into the car and i was wondering if i should just go ahead and sell my diagnostic equipment that i used in my 01 altima.
i have a 95, and its OBD1, but if you look at the plate it will tell you the production date, mine was produced in the 4th quarter of 94, but i believe yours would still be OBD1 as well, just look at the plate if its early 95 or late 94 then it most likely is.
Mine 95 accord ex coupe is OBD-I. If you are unsure, go look under your car and if you see 2 O2 sensors (1 infront of the cat and one after) then you have OBD-II if you have only one (infront of the catalytic) then it is OBD-I.
