WOOOT!
As some of you know i blew my b16 with top fuel stg 2 cams goin up to seattle for the honda-tech meet
i had to finish up my partially completed NA swap
gsr block with ctr pistons b16 head with the top fuel cams but i had to use stock cause they are fuqed now
anyways after days of working on it on and off due to employment me and my friends got the motor in and it fired up the first try!
i will get pics soon i wanted to get pics of the build process but i did not have the time at the moment, at the time i was desperate in getting my car up and running again!
yay for me its the first motor i put together
i torqued everything down to spec too makin sure i did that **** right
i got to put in the axles put coolant in the motor, hook up the heater core, and adjust the timing belt its uneven with all of the gears and is scrapin the valve cover
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur »</TD></TR><TR><TD CLASS="quote">Nice. Much more satifying when you do it yourself. Doin it right he first time. I'm in for pics</TD></TR></TABLE> X2
heres the run down...my car was dying at operating temp but it was the iacv
after that my friend put in the wrong firing order but i fixed that right after the first drive lol
now its running like a champ no codes or nothin!
ill get pics tommorrow of the motor and shiznits!
RedEj8
Jun 1, 2005 06:40 PM
