Do I have an LSD tranny?
Old Jul 19, 2007 | 09:38 PM
TodaSi's Avatar
Default Do I have an LSD tranny?
I have searched and searched, but have found nothing concrete about whether or not my B16a SIR II swap has an LSD tranny or not. I paid an extra $200 for an LSD tranny, but don't think I have one...and I don't want to find out after I install the engine/trans. It's an S4C tranny, but it doesn't have LSD stamped on it like the first gen B16's do. I heard you can tell by looking into the case where the half shafts insert, but not sure what to look for. Here are a couple of pictures.
I also received the engine with everything just hacked off, TPS sensor broke (does this happen on every JDM B Series? lol), hydro tranny bleed screw broke off, etc.
Old Jul 19, 2007 | 09:44 PM
Hybrid96EK's Avatar
Default Re: Do I have an LSD tranny? (TodaSi)
Nope. Not an LSD unit.
Old Jul 19, 2007 | 10:05 PM
TodaSi's Avatar
Default Re: Do I have an LSD tranny? (Hybrid96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid96EK &raquo;</TD></TR><TR><TD CLASS="quote">Nope. Not an LSD unit.</TD></TR></TABLE>
I should see the diff's gears in the pictures, and not that bar correct? Basically you can see right through except for that bar down the center.
Old Jul 19, 2007 | 10:18 PM
5_Lug_B's Avatar
* B A N N E D *
No LSD, sorry meng. Send it back
Old Jul 19, 2007 | 11:50 PM
Rd91SiB18ls's Avatar
Default Re: Do I have an LSD tranny? (5_Lug_B)
def nor lsd you should be able to see thruogh
the diff, that sucks send it back if you can.
Old Jul 20, 2007 | 01:07 AM
Winlight's Avatar
Default Re: Do I have an LSD tranny? (Rd91SiB18ls)
who did you buy it from?
Old Jul 20, 2007 | 01:31 AM
Richard...'s Avatar
Default Re: Do I have an LSD tranny? (Winlight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Winlight &raquo;</TD></TR><TR><TD CLASS="quote">who did you buy it from?</TD></TR></TABLE>
X2
hope that helps?
Old Jul 20, 2007 | 06:53 AM
TodaSi's Avatar
Default Re: Do I have an LSD tranny? (richard7968)
I bought it from Osaka Japanese Auto Parts Inc. in Canada.
Quick question, is the LSD helical like the ITR? Is it worth the $200 or would an $800 Quaife be better?
Sweet picture, "save as" Hope this post helps others.
Now, I have to take care of business and get this resolved.
Old Jul 20, 2007 | 07:12 AM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">I bought it from Osaka Japanese Auto Parts Inc. in Canada.
Now, I have to take care of business and get this resolved. </TD></TR></TABLE>
thanks!
and if you want an LSD get your self the OBX one they have a sale on honda-tech right how in the performance section of this forum
oh and the shimming problem has been taken care of now on the OBX LSD's so no need to worry about any preload problems!
Old Jul 23, 2007 | 12:12 PM
sleepencivic's Avatar
do the quaiff lsd have a pin or can you see through those also?
Old Jul 23, 2007 | 01:13 PM
Richard...'s Avatar
Default Re: Do I have an LSD tranny? (sleepencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepencivic &raquo;</TD></TR><TR><TD CLASS="quote">do the quaiff lsd have a pin or can you see through those also?</TD></TR></TABLE>
perhaps you missed it the first time so i will repeat my self!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by richard7968 &raquo;</TD></TR><TR><TD CLASS="quote">
hope that helps?</TD></TR></TABLE>
Old Jul 24, 2007 | 05:01 AM
no i read it the first time *** i was just wondering if the aftermarket lsd had the same identifining features as the oem ***
Old Jul 24, 2007 | 06:26 AM
Bense's Avatar
quaife and obx use a smaller hole, but when you look in it it's obvious that there's no cross pin (the bar thru diff)
Old Jul 24, 2007 | 12:46 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepencivic &raquo;</TD></TR><TR><TD CLASS="quote">no i read it the first time *** i was just wondering if the aftermarket lsd had the same identifining features as the oem ***</TD></TR></TABLE>
is that suppose to be derived at me?
Old Jul 25, 2007 | 05:58 AM
Mr.OB*GYN_Rhett's Avatar
wait i think you bought from one of the shadiest shops ever lol
Old Jul 25, 2007 | 07:25 AM
TodaSi's Avatar
Default Re: Do I have an LSD tranny? (Mr.OB*GYN_Rhett)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.OB*GYN_Rhett &raquo;</TD></TR><TR><TD CLASS="quote">wait i think you bought from one of the shadiest shops ever lol </TD></TR></TABLE>
I did?
Old Jul 25, 2007 | 07:52 AM
go to Search&gt; Archived&gt; "osaka"
Old Jul 25, 2007 | 07:58 AM
spAdam's Avatar
Loved
Community Favorite
whoa... no need for name calling, even though that was a valid question with a short answer... maybe some explanation is in order...
The pin that you see when you look through the axle hole of an open differential is the shaft that the spider gears rotate on. The spider gears are the gears that are free to rotate against the outputs of the differential... they are the reason why when you spin a wheel by hand on your open diff car the opposite wheel spins the other way.
LSDs are designed with either a system of clutches, helical gears, or a viscous coupling and simply don't have that shaft because spider gears are not part of their design.
Old Jul 25, 2007 | 08:00 AM
apSquidFace's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.OB*GYN_Rhett &raquo;</TD></TR><TR><TD CLASS="quote">go to Search&gt; Archived&gt; "osaka"</TD></TR></TABLE>
dont you work there
Old Jul 26, 2007 | 06:01 AM
yes it was
Old Jul 26, 2007 | 06:45 AM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TodaSi &raquo;</TD></TR><TR><TD CLASS="quote">Osaka</TD></TR></TABLE>
I also received the engine with everything just hacked off, TPS sensor broke (does this happen on every JDM B Series? lol), hydro tranny bleed screw broke off, etc. </TD></TR></TABLE>
nuff said.
i still don't understand why anyone at this point is patronizing Osaka. HMO offers perfect swaps and unprecedented customer service!
the plain fact is that Osaka sucks in pretty much any way such a business can suck.
you mean "supposed" and "directed"
Old Jul 26, 2007 | 08:22 AM
TodaSi's Avatar
Default Re: Do I have an LSD tranny? (builthatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by builthatch &raquo;</TD></TR><TR><TD CLASS="quote">
nuff said.
I have to agree...even though I just bought my engine from there, I really wish I didn't. I bought it (really my son did) off from ebay where the seller has a perfect rating...I didn't know it was Osaka until it arrived and it was on the billing. I was very dissapointed with the condition of the engine...especially the harness. I have bought 2 engines both from IAS and they were beyond perfect, this engine was all hacked up. Not one complete hose, or wire on it. It looks to be an okay engine and should run well.
I'm rarely on H-T anymore and should have done more investigation before buying it off ebay. My bad. Anyway, it's been too long and I still don't have a credit from getting the wrong transmission. Maybe today I'll get my refund.
Old Jul 26, 2007 | 08:30 AM
builthatch's Avatar
MiG-21 superfan
I'm rarely on H-T anymore and should have done more investigation before buying it off ebay. My bad. Anyway, it's been too long and I still don't have a credit from getting the wrong transmission. Maybe today I'll get my refund.</TD></TR></TABLE>
well, you live and you learn, no matter how old ; )
IAS def provides nice stuff; it's just a shame tho because they've bailed out of stocking alot of the swaps anymore. i've called twice in the past couple months inquiring and both times all they had were b18b.
good luck with your case against those thievin' hacks up there!
Old Jul 26, 2007 | 11:21 AM
try noyan in northern va have bought several nice swaps from them http://www.noyan.com
Old Jul 26, 2007 | 03:25 PM
Richard...'s Avatar
you mean "supposed" and "directed" </TD></TR></TABLE>
Either way both sentences would pass a grammar check, to which both conclude the same meaning or point of view however you want to put it?
HEY if your still not convince run the damn sentence though a grammar checker such as MS word or something!
Oh and while were talking of grammar and punctuation shouldn't you start your sentence with a capital letter LOL
i highlighted the mistake!!!!
