I have a friend who will not listen.... Please HELP!!!
I need some assistance out there. I have a friend who previously built an LS/vtec bored to 2.1 with 13.5 comp pistons, flat faced valves, s2 pro 2 cams, extreme port an polish, and of course rods, bolts, v springs, etc.... He had a shitty tune done on the car the day the motor was started. The car came from the dyno smelling like gas, and his valves punched there way through the pistons that night. (All this occurred before I knew this guy)
Now I am trying to prevent this from happening a second time, but he just will not listen. He has currently built the same setup except this time running 14.1 comp pistons along with flat valves. He thinks he can run this bomb on pump gas with the same tune from the previous detonation. I appreciate all input on the matter....
You are pushing it with that comp ratio. Not only that but he needs to check clearences first as well between the valves and pistons that also could be an issue.
aight I know the guy too.. this is the full set up from BEFORE AND NOW
BEFORE:
B18B1 Block
B16 Head
Type R Tranny
Darton Sleeves
ARP Head bolts
85mm 13.2:1 Weisco Pistons
Eagle Rods
Eagle Crank
Extreme Port and Polish
Port Match on the Headers, Throttle body, and intake manifold to the ports on the head
70MM throttle body
Skunk 2 Pro Series Intake Manifold
DC 4:2:1 Headers
Skunk 2 Pro 2 cams
AEM cam gears
Type R oil cooler
Greddy timing belt
Unorthodox Lightweight pulleys
Skunk 2 Valve springs
Skunk 2 Retainers
Ferrea Intake and Exhaust 1mm oversized valves
7 Angle valve job
MSD ignition
Ebay 2.5 catback exhaust
Hi Flow Cat
Running 93 Octane Gas
Hondata
CRAPPY TUNE - car came back running super rich, STANK like gas and cams sounding like a v8.. you know the sound.
This set up made 199.8 WHP and 149 150 ish ft/lb torque
Engine blew with in 6 hours of getting it back, he broke a valve guild, broke a valve, and the valve punched holes in the piston top and then scattered tiny pieces metal throughout the whole head and put scratches in his cylinder walls.
NOW
B18B1 Block
B16 Head
Type R Tranny
Darton Sleeves
ARP Head Bolts
84.5mm 14.1:1 Weisco Pistons
Eagle Rods
Eagle Crank
NO Port and Polish
NO Port Match on the Headers, Throttle body, and intake manifold
ITBS
Rage Headers
Skunk 2 Pro 2 cams
AEM cam gears
Type R oil cooler
Greddy timing belt
Skunk 2 Retainers
Skunk 2 Flatfaced High comp vavles
7 angle valve job
MSD ignition
Ebay 3.0 catback exhaust
Test Pipe
WANTS to run 93 octane gas
WANTS to put back in the ECU from the build before with the crappy tune as the break in before he gets it dyno'd and tuned.
expecting 260WHP with is build is what he says
Modified by wishihadaneg at 11:08 PM 7/19/2007
Modified by wishihadaneg at 10:57 AM 7/20/2007
BEFORE:
B18B1 Block
B16 Head
Type R Tranny
Darton Sleeves
ARP Head bolts
Eagle Rods
Eagle Crank
70MM throttle body
DC 4:2:1 Headers
Skunk 2 Pro 2 cams
AEM cam gears
Type R oil cooler
Greddy timing belt
Skunk 2 Retainers
7 Angle valve job
MSD ignition
Hi Flow Cat
Hondata
NOW
B18B1 Block
B16 Head
Type R Tranny
Darton Sleeves
ARP Head Bolts
Eagle Rods
Eagle Crank
NO Port and Polish
ITBS
Rage Headers
Skunk 2 Pro 2 cams
AEM cam gears
Type R oil cooler
Greddy timing belt
Skunk 2 Retainers
7 angle valve job
MSD ignition
Test Pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green eyed bandit »</TD></TR><TR><TD CLASS="quote">and his valves punched there way through the pistons that night. </TD></TR></TABLE>
That is not a shitty tune, that is called mechanical interference.
The best tune in the world will not prevent engine damage when the pistons kiss the valves.
He only made a 199 whp with the old setup?? That sucks. His motor will go to **** again if he tries to run 14:1 on 93 octane. Just let him learn again. 260 whp
not gonna happen.
not gonna happen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wishihadaneg »</TD></TR><TR><TD CLASS="quote">
NOW
B18B1 Block
B16 Head
Type R Tranny
Darton Sleeves
ARP Head Bolts
Eagle Rods
Eagle Crank
NO Port and Polish
70MM throttle body
ITBS
Rage Headers
Skunk 2 Pro 2 cams
AEM cam gears
Type R oil cooler
Greddy timing belt
Skunk 2 Retainers
7 angle valve job
MSD ignition
Test Pipe
Modified by wishihadaneg at 11:08 PM 7/19/2007</TD></TR></TABLE>
how does he have ITB's, no port match on the throttle body, AND ITB's?
either you just threw together a 17 year old honda fan boy christmas list or you dont know what you're talking about
NOW
B18B1 Block
B16 Head
Type R Tranny
Darton Sleeves
ARP Head Bolts
Eagle Rods
Eagle Crank
NO Port and Polish
70MM throttle body
ITBS
Rage Headers
Skunk 2 Pro 2 cams
AEM cam gears
Type R oil cooler
Greddy timing belt
Skunk 2 Retainers
7 angle valve job
MSD ignition
Test Pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JJSpecTuning »</TD></TR><TR><TD CLASS="quote">
either you just threw together a 17 year old honda fan boy christmas list or you dont know what you're talking about</TD></TR></TABLE>
opps my bad, i just copied and pasted from the "before" time, my bad, no throttle body.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i »</TD></TR><TR><TD CLASS="quote">can you say BOOM!
93 octane lol</TD></TR></TABLE>
if he wont listen then just let him do it, when it blows up just tell him, "I told u that siht was gonna blow" or "shouldve listened to me" or u can always just laugh in his face! if they wont listen then just wait till it blows, wat else can u do? he probably thinks that u dont know as much as he does!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t-town_ep »</TD></TR><TR><TD CLASS="quote">if he wont listen then just let him do it, when it blows up just tell him, "I told u that siht was gonna blow" or "shouldve listened to me" or u can always just laugh in his face! if they wont listen then just wait till it blows, wat else can u do? he probably thinks that u dont know as much as he does!</TD></TR></TABLE>
That's exactly what it is. He might know more than I do on somethings, but this **** is common sense...
Ya damn right....I'm actually going to bet him $200 that the motor doesn't make out of the break in period. He said he's going to drive the car for a 1000 miles for the break in period....not going to happen
