problem with my brakes
Old Jul 19, 2007 | 07:57 PM
Cyber ITR's Avatar
Default problem with my brakes
i just currently start to drive my ef crx again after its been stored for over 1.5years and i noticed that my brake pedal after driving the car about an hour or so is sometimes right on the floor and i have to pump the pedal to get pressure
the car has no problem before i put it in storage
help
Old Jul 19, 2007 | 09:20 PM
shortA25's Avatar
Default Re: problem with my brakes (Cyber ITR)
I'm thinking your master cylinder has gone bad. Try replacing that along with bleeding the brakes with fresh, clean fluid. If that doesn't work, move onto your brake booster and brake lines. The prop valve should be fine, they don't really go bad. Good luck.
- short-A
Old Jul 19, 2007 | 09:24 PM
DenzComp's Avatar
You have brakes again once you let it sit for awhile?
Old Jul 20, 2007 | 02:26 AM
Cyber ITR's Avatar
Default Re: (DenzComp)
could it be that the brake fluid mixed with moisture that lead to this ?
Old Jul 20, 2007 | 05:28 AM
mahatma's Avatar
Default Re: (Cyber ITR)
probably master cylinder. more likely than moisture making it's way in.
Old Jul 20, 2007 | 11:04 PM
Cyber ITR's Avatar
Default Re: (mahatma)
are all EFs master cylinder the same ??
my crx is a genuine EF8
thanks
tangerinebeast
Mar 17, 2012 07:03 AM
Ueichi
Feb 25, 2011 02:25 PM
SlammedEG6
Aug 16, 2010 12:46 PM
pedroa06
Sep 3, 2009 06:23 PM
4play4dr
Nov 13, 2006 11:39 AM
