power steering BELT CHANGE
Old Jul 19, 2007 | 06:50 PM
TMC_EF's Avatar
Default power steering BELT CHANGE
I am planning to change my power steering belt and want to know if any body and a quick write up of it
Old Jul 19, 2007 | 07:01 PM
hondadude's Avatar
Default Re: power steering BELT CHANGE (TMC_EF)
On the underhood sticker it will tell you WHAT YEAR the Accord is.
Old Jul 19, 2007 | 07:11 PM
TMC_EF's Avatar
Default Re: power steering BELT CHANGE (hondadude)
the car is a 91 EX 4dr
Old Jul 19, 2007 | 07:58 PM
hondadude's Avatar
12mm nut on the lower part of the P/S unit and 14mm bolt on the top pivot point.
Some times it's hard to get on to the top 14mm bolt as the P/S pipe is in the way, but it's only 2 10mm bolts to get the pipe off the P/S pump.
when you have the top and bottom bolts loose, look in from the front under the pump and you'll see a 10mm that is a long threaded bolt to actually tension the pump unit.
broken_lude
Dec 11, 2006 08:46 PM
namsoofabolus
Apr 24, 2006 02:22 PM
breezer69
Dec 31, 2004 02:32 PM
digitalh3lix
Dec 13, 2004 01:11 PM
ITR164
Jun 17, 2003 05:40 PM
