What do you use to remove your oil filter?
Old Jul 19, 2007 | 05:19 PM
Nocturnal's Avatar
Default What do you use to remove your oil filter?
Anyone recommend a good tool? The last time I ended ups tabbing it with a screwdriver since it wouldn't come off. Let me just say that that made a huge mess.
Old Jul 19, 2007 | 05:21 PM
philosofy1's Avatar
Default Re: What do you use to remove your oil filter? (Nocturnal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nocturnal &raquo;</TD></TR><TR><TD CLASS="quote">Anyone recommend a good tool? The last time I ended ups tabbing it with a screwdriver since it wouldn't come off. Let me just say that that made a huge mess.</TD></TR></TABLE>
i use a pair of rubber gripped gloves. if that doesn't work, there are clamps, and sockets made to go over the filter, in use of a socket wrench as well.
Old Jul 19, 2007 | 05:35 PM
MrRabbit87's Avatar
Default Re: What do you use to remove your oil filter? (philosofy1)
if all else fails... get a screw driver with a hammer and alot of rags lol....
Old Jul 19, 2007 | 05:38 PM
93baggedcivic's Avatar
Default Re: What do you use to remove your oil filter? (MrRabbit87)
go to any parts store and get one of the oil filter wrenches and use that they cost like no more then 10 bucks.
Old Jul 19, 2007 | 05:43 PM
eG6 driver3's Avatar
I use this thing to loosen jars and it works when I do an oil change. After you get it off I suggest you use a K&N oil filter. It's called K&N Wrench-off.
knfilters.com
Old Jul 19, 2007 | 05:47 PM
philosofy1's Avatar
Default Re: What do you use to remove your oil filter? (solbrothers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by solbrothers &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
HAHAHAHA, the best tool ever!
Old Jul 19, 2007 | 05:48 PM
trrbl1bmx's Avatar
An oil filter should only be that tight ONE time. If you are doing your own oil changes, make sure your lubing the gasket good, and screwing it on with your hands, snug. It doesn't have to be that tight. At work all we use for honda's are band wrenches and filter pliers for the k series.
Old Jul 19, 2007 | 05:49 PM
SIC-CIVIC's Avatar
you should be able to take it off with your hands, there is no need for it to be any tighter then that.
Old Jul 19, 2007 | 05:53 PM
MeanGreenMachine's Avatar
Default Re: (SIC-CIVIC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIC-CIVIC &raquo;</TD></TR><TR><TD CLASS="quote">you should be able to take it off with your hands, there is no need for it to be any tighter then that.</TD></TR></TABLE>
Old Jul 19, 2007 | 05:57 PM
STREETWERKZ's Avatar
I use an OEM Honda tool.
part number: 07HAA-PJ70101
i also have one of those plastic ones floating around in one of my many toolboxes. \/ \/ \/ \/ \/
Syndacate's Avatar
Use an oil filter wrench...works 10 out of 10 times...
Not that multi-size bullshit strap wrench either - use a real filter wrench:
Works every time, like &lt;10 bux from autozone.
philosofy1's Avatar
i agree with you 100%, i guess some people don't have the strength needed to get it off.
Old Jul 19, 2007 | 06:01 PM
posHonda's Avatar
who tightens their oil filter to the point where they cant take it off?
Old Jul 19, 2007 | 06:02 PM
Syndacate's Avatar
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
i agree with you 100%, i guess some people don't have the strength needed to get it off.</TD></TR></TABLE>
If you have rubber gloves that's possible, usually it's not a matter of strength, it's a matter of room. I noticed on the '04 LX's that it's a pain in the *** and REALLY hard to get 2 hands up there none-the-less get both hands around the oil filter so you can turn it w/ sufficient torque. I used rubber gloves.
Yeah, but sometimes it's tighter than that, my basic rule - if I can't break it loose w/ my hands, don't even bother un-doing the drain plug - wait until I can get a wrench or something to definitely do it.
Mercdes benz makes REALLY GOOD filter wrenches, they're like the ones I posted above, but they have screws in 2 of the sides, so you can just tighten them down according to the new filter, and pop it on, and it basically sizes down to a variety of sizes.
Benz FTW!!!
Old Jul 19, 2007 | 06:03 PM
Syndacate's Avatar
Default Re: (iVteC_PoWeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iVteC_PoWeR &raquo;</TD></TR><TR><TD CLASS="quote">who tightens their oil filter to the point where they cant take it off?</TD></TR></TABLE>
Manufacturers, garages, take your pick, it's usually not the initial tighten, it's usually how tight it is 5000 miles later.
Old Jul 19, 2007 | 06:06 PM
egb16pg's Avatar
Default Re: (Syndacate)
if you want to get ghetto a belt gets a good grip.
Old Jul 19, 2007 | 06:08 PM
i went back and snapped some pics.
Old Jul 19, 2007 | 06:14 PM
MrRabbit87's Avatar
Default Re: (STREETWERKZ)
USE A SCREW DRIVER AND SHOW THE FILTER HOW MUCH YOU HATE IT AND SHANK THE HELL OUT OF IT!!!! then go take a shower and light a cigarette
Old Jul 19, 2007 | 06:37 PM
n1_egsex's Avatar
* B A N N E D *
Default Re: (MrRabbit87)
sandpaper works sometimes
Old Jul 19, 2007 | 08:15 PM
KillSwitch's Avatar
Default Re: (JJSpecTuning)
band wrenches work real good. if that doesn't work use really big pliers
Old Jul 19, 2007 | 08:26 PM
BEE1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">I use an OEM Honda tool.
I have the same one
Old Jul 19, 2007 | 09:02 PM
elfather's Avatar
Default Re: (BEE1)
nice
Old Jul 19, 2007 | 09:14 PM
SiRek4
Guest
Posts: n/a
Hahaha, I love you Screach
b18 hatch mike
Apr 24, 2008 08:32 PM
eL
Honda Civic (2006 - 2015)
Jan 7, 2007 06:17 PM
EJ8VTEC
Aug 30, 2005 12:28 PM
csfalcon
Jan 6, 2002 10:29 AM
