OIL PAN GASKET
Old Jul 19, 2007 | 04:10 PM
red02s2k's Avatar
Default OIL PAN GASKET
my old oil pan gasket was leaking a little so put in a new one and it still is. So i guess what i am saying is there a bolt pattern that i should have followed b/c it's still leaks???
Old Jul 19, 2007 | 04:32 PM
red02s2k's Avatar
it sucks b/c i don't want to take it off again to check
Old Jul 19, 2007 | 04:35 PM
1992Si's Avatar
Make sure the pan rail is straight. Did the pan get hit or something.
Normally they never leak.
You should only need 4 small dabs of sealant on the four sharp corners
Old Jul 19, 2007 | 05:50 PM
muasboi's Avatar
Default Re: (1992Si)
i think you forgot to fully clean the surface. because usually what happens is the OLD o-ring's (4 of them) get stuck to the block, and when you go to put the new gasket on, you are DOUBLING the o-rings, causing you to have a gap, therefore leakage
hope that helps.
Old Jul 19, 2007 | 06:58 PM
red02s2k's Avatar
Default Re: (muasboi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by muasboi &raquo;</TD></TR><TR><TD CLASS="quote">i think you forgot to fully clean the surface. because usually what happens is the OLD o-ring's (4 of them) get stuck to the block, and when you go to put the new gasket on, you are DOUBLING the o-rings, causing you to have a gap, therefore leakage
hope that helps.</TD></TR></TABLE>
yea i know lol thanks it's not my first time.. i just couldn't remember if there was bolt pattern.. lol yea i know i should have cleaned the motor a little better... i did it in the middle of the night but i just checked and some of the bolts came loss
thanks
Old Jul 19, 2007 | 07:46 PM
muasboi's Avatar
well, as far as bolt patterns go..its usually safe to say that you start in the middle and alternate outwards...
and those little bolts & nuts don't require much torque
gl!!
Old Jul 19, 2007 | 08:02 PM
trrbl1bmx's Avatar
More than likely if you have a steel oil pan, its bent. If it is D series or H series you can swap out for OEM aluminum oil pan that wont bend. Can be had for fairly cheap.
Freshdot
May 18, 2010 06:52 AM
eg_21
May 2, 2010 11:04 AM
EJ8_Enthusiast
Aug 3, 2008 08:32 AM
StreetRacinThug
Dec 21, 2006 08:44 AM
