Front hub for std
Old Jul 19, 2007 | 04:07 PM
esteen2's Avatar
Default Front hub for std
I have an 88 civic std with the small spline hubs and I want to upgrade. Which hubs should I use (needs to be off a civic so my brakes will work), and can I put the bigger hub in my stock knuckels? I am also going the change the berarings when I do the hub swap.
Old Jul 19, 2007 | 04:10 PM
onepoint6i's Avatar
Default Re: Front hub for std (S2R Honda)
anything not HF 88-91 is the same..i would upgrade to DA hubs/knuckles for the bigger rotors and calipers..
edit: just replace the whole knuckle with all new bearings
Old Jul 19, 2007 | 04:13 PM
garageEF's Avatar
Default Re: Front hub for std (onepoint6i)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">anything not HF 88-91 is the same..</TD></TR></TABLE>
not true... there are 26 spline hubs and 23 spline hubs.
Old Jul 19, 2007 | 05:04 PM
onepoint6i's Avatar
Default Re: Front hub for std (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">not true... there are 26 spline hubs and 23 spline hubs.</TD></TR></TABLE>
ok list them..what models came with 23 and which with 26?
Old Jul 19, 2007 | 05:08 PM
esteen2's Avatar
Std civic has 23 spline hubs I want to upgrade to 26 spline, but i wanted to know what hubs are 26 spline and if the will fit in the std knuckle?
Old Jul 19, 2007 | 05:14 PM
onepoint6i's Avatar
all std/hf are 23 splines..
all other are 26splines meaning 88-91 DX and Si are 26 splines..
the hub with a 26 spline will not fit a knuckle with a 23 spline hub..you will need to
upgrade to a 26spline knuckle/hub
like i said before, you might as well uprgrade to DA or SiR knuckles and install new bearings while you are at it..
Old Jul 19, 2007 | 09:14 PM
shortA25's Avatar
I'd swap the entire knuckles/spindles for DA Integra or 90-91 Civic EX if you can find them. That way you already have the knuckles in place for a bigger brake upgrade. Later,
- short-A
Old Jul 20, 2007 | 12:02 AM
garageEF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">anything not HF 88-91 is the same.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onepoint6i &raquo;</TD></TR><TR><TD CLASS="quote">all std/hf are 23 splines..
hmmm....
Old Jul 20, 2007 | 12:05 AM
Ghett0_ed's Avatar
pwnd
Old Jul 20, 2007 | 06:45 AM
onepoint6i's Avatar
hmmm....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ghett0_ed &raquo;</TD></TR><TR><TD CLASS="quote">pwnd</TD></TR></TABLE>
ninjagaiden
14
Sep 7, 2007 02:11 PM
Deo
Aug 3, 2005 06:52 PM
Floored
Jul 23, 2005 03:29 AM
99teggsr
Feb 25, 2005 11:55 AM
jdmrex91
Jul 1, 2004 05:03 PM
