1997 crv vibration problems
ok, here is the deal. this thing use to have 19" spinners on it(i know, gay right) but it has vibrations everywhere. i replaced the 2 rubber isolaters in the rear that hold the rear to the body. rear vibes are gone. now to the front. this thing only vibrate on acceleration. i replaced all the motor mounts except the one on the tranny(top) both axles replaced . there is no worn out parts or wheel bearings in this vehicle. i am at wits end here and i am starting to think that the trouble is in the transmission. any and all help greaztly appreciated.
A shudder under acceleration usually means something is out of balance in the drivetrain. If you had larger/heavier wheels on the car, they may have put a lot of stress on the axles/rear end/transfer case/etc.
Check the carrier bearing on the main driveshaft that runs from the transmission to the rear end. It's also best to be able to put the car on a lift and have someone drive it while you are under the car inspecting it. If something is out of balance, it's easier to allocate it this way.
Good luck,
AJ
Good luck,
AJ
