concerns about my new exhaust
Old Jul 19, 2007 | 02:55 PM
xTimmyx's Avatar
Default concerns about my new exhaust
my new exhaust will consist of 2.5" pipping, DC sports headers, with magnaflow caty/muffler/tip.
what i'm kinda concerned is the back pressure...do you think they'll be enough, or nothing at all, that it will start to do damage to the engine over time (or so i heard from other people)
Old Jul 19, 2007 | 03:03 PM
crazykamper's Avatar
sounds like a good setup... depending on what you are runnin already... im probably gonna be runnin that same exact setup soon as i get some more $$...
Old Jul 19, 2007 | 03:04 PM
xTimmyx's Avatar
Default Re: (crazykamper)
with my motor set up i have a sohc zc with cold air intake if that helps any.
i think i know for a fact that this is gonna be a LOUD exhaust system. so i might just go with a resonator. and my tip is HUGE i really dont wanting it to look ricey at all, so i might just leave the current one on there.
Old Jul 19, 2007 | 03:06 PM
basicaly just i/h/e then.... the piping is pretty big.... i would go with a 2.25 if i were you... unless you plan on doing more mods later on down the road....
edit: im gonna be runnin 2.25 pipin... its pleanty... unless you go f/i...
Old Jul 19, 2007 | 03:07 PM
SIred91's Avatar
Rainman
Default Re: (xTimmyx)
Dude, you need to go into the FAQ and read my write up on backpressure.
I can't believe some of the crap people think about Honda and backpressure.
srsly funny.
Old Jul 19, 2007 | 03:08 PM
haha, gotta love honda's and pack pressure, hahahahahahaha
Old Jul 19, 2007 | 03:12 PM
SIred91's Avatar
Rainman
"pack" pressure?
Old Jul 19, 2007 | 03:26 PM
xTimmyx's Avatar
Default Re: (SIred91)
actually i tried to find it.....couldnt find it. can ya link me? please
Old Jul 19, 2007 | 03:30 PM
Ass$nyper's Avatar
Pirate General...YARRRR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, you need to go into the FAQ and read my write up on backpressure.
srsly funny.</TD></TR></TABLE>
I remember that, I patted you on the head and gave you 2 whole cupcakes and some gatorate in lemon lime.
I thought I was the only one who got it.
Old Jul 19, 2007 | 03:32 PM
SIred91's Avatar
Rainman
Read this--------------:
Back pressure, Exhaust velocity and scavenging.
The myth: “engines need some backpressure.”
One of the most misunderstood concepts in exhaust theory is backpressure. People love to talk about backpressure on message boards with no real understanding of what it is and what its consequences are. I'm sure many of you have heard or read the phrase "engines need some backpressure" when discussing exhaust upgrades. That phrase is in fact completely inaccurate and a wholly misguided notion.
How the myth came about:
It is easy to see how this misunderstanding arises. Lets’ say that Max puts a 3-inch system on his normally aspirated car. He soon realizes that he has lost power right through the power band. The connection is made in his throbbing brain….
Put on 3" pipe = loss of backpressure = loss of power.
Max erroneously concludes that you need backpressure to retain performance. He has ignored the need for exhaust gas velocity to get that scavenge effect.
The other myth: “engines can get burned valves from not enough backpressure”
How this myth came about:
The other reason why people say "backpressure is good" is because they hear that cars (or motorcycles) that have had performance exhaust work done to them would then go on to burn exhaust valves. Now, it is true that such valve burning has occurred as a result of the exhaust mods, but it isn't due merely to a lack of backpressure.
The internal combustion engine is a complex, dynamic collection of different systems working together to convert the stored power in gasoline into mechanical energy to push a car down the road. Anytime one of these systems are modified, that mod will also indirectly affect the other systems, as well.
Now, valve burning occurs as a result of a very lean-burning engine. In order to achieve a theoretical optimal combustion, an engine needs 14.7 parts of oxygen by mass to 1 part of gasoline (again, by mass). This is referred to as a stochiometric (chemically correct) mixture, and is commonly referred to as a 14.7:1 mix. If an engine burns with less oxygen present (13:1, 12:1, etc...), it is said to run rich. Conversely, if the engine runs with more oxygen present (16:1, 17:1, etc...), it is said to run lean. Today's engines are designed to run at 14.7:1 for normally cruising, with rich mixtures on acceleration or warm-up, and lean mixtures while decelerating.
Getting back to the discussion, the reason that exhaust valves burn is because the engine is burning lean. Normal engines will tolerate lean burning for a little bit, but not for sustained periods of time. The reason why the engine is burning lean to begin with is that the reduction in backpressure is causing more air to be drawn into the combustion chamber than before. Earlier cars (and motorcycles) with carburetion often could not adjust for his.
Once these vehicles received performance mods that reduced backpressure, they tended to burn valves because of the resulting over-lean condition. This, incidentally, also provides a basis for the "torque increase" seen if backpressure is maintained. As the fuel/air mixture becomes leaner, the resultant combustion will produce progressively less and less of the force needed to produce torque.
Some basic exhaust theory
Your exhaust system is designed to evacuate gases from the combustion chamber quickly and efficiently. Exhaust gases are not produced in a smooth stream; exhaust gases originate in pulses. A 4 cylinder motor will have 4 distinct pulses per complete engine cycle; a 6 cylinder has 6 pulses and so on. The more pulses that are produced, the more continuous the exhaust flow. Backpressure can be loosely defined as the resistance to positive flow - in this case, the resistance to positive flow of the exhaust stream.
Backpressure and velocity.
Some people operate under the misguided notion that wider pipes are more effective at clearing the combustion chamber than narrower pipes. It's not hard to see how this misconception is appealing - wider pipes have the capability to flow more than narrower pipes. So if they have the ability to flow more, why isn't "wider is better" a good rule of thumb for exhaust upgrading? In a word - VELOCITY. I'm sure that all of you have at one time used a garden hose w/o a spray nozzle on it. If you let the water just run unrestricted out of the house it flows at a rather slow rate. However, if you take your finger and cover part of the opening, the water will flow out at a much, much, faster rate.
The astute exhaust designer knows that you must balance flow capacity with velocity. You want the exhaust gases to exit the chamber and speed along at the highest velocity possible - you want a FAST exhaust stream. If you have two exhaust pulses of equal volume, one in a 2" pipe and one in a 3" pipe, the pulse in the 2" pipe will be traveling considerably FASTER than the pulse in the 3" pipe. While it is true that the narrower the pipe, the higher the velocity of the exiting gases, you want make sure the pipe is wide enough so that there is as little backpressure as possible while maintaining suitable exhaust gas velocity.
Backpressure in its most extreme form can lead to reversion of the exhaust stream - that is to say the exhaust flows backwards, which is not good. The trick is to have a pipe that that is as narrow as possible while having as close to zero backpressure as possible at the RPM range you want your power band to be located at. Exhaust pipe diameters are best suited to a particular RPM range. A smaller pipe diameter will produce higher exhaust velocities at a lower RPM but create unacceptably high amounts of backpressure at high rpm. Thus if your power band is located 2-3000 RPM you'd want a narrower pipe than if your power band is located at 8-9000RPM.
Many engineers try to work around the RPM specific nature of pipe diameters by using setups that are capable of creating a similar effect as a change in pipe diameter on the fly. The most advanced is Ferrari's which consists of two exhaust paths after the header - at low RPM only one path is open to maintain exhaust velocity, but as RPM climbs and exhaust volume increases, the second path is opened to curb backpressure - since there is greater exhaust volume there is no loss in flow velocity. BMW and Nissan use a simpler and less effective method - there is a single exhaust path to the muffler; the muffler has two paths; one path is closed at low RPM but both are open at high RPM.
So why is exhaust velocity so important?
The faster an exhaust pulse moves, the better it can scavenge out all of the spent gasses during valve overlap. The guiding principles of exhaust pulse scavenging are a bit beyond the scope of this doc but the general idea is a fast moving pulse creates a low pressure area behind it. This low pressure area acts as a vacuum and draws along the air behind it. A similar example would be a vehicle traveling at a high rate of speed on a dusty road. There is a low pressure area immediately behind the moving vehicle - dust particles get sucked into this low pressure area causing it to collect on the back of the vehicle. This effect is most noticeable on vans and hatchbacks which tend to create large trailing low pressure areas - giving rise to the numerous "wash me please" messages written in the thickly collected dust on the rear door(s).
Conclusion.
SO it turns out that engines don't need backpressure, they need as high a flow velocity as possible with as little backpressure as possible.
Old Jul 19, 2007 | 04:07 PM
^ some damn good write up... thats for sure...
Old Jul 19, 2007 | 07:49 PM
xTimmyx's Avatar
NICE.... i like.... alright i think i should be fine with my system.
only i do think its gonna be way too loud lololl. regardless there WILL be vid and sound clips of when its all installed.
94trouble
Jun 14, 2011 08:00 PM
Memo6453
Honda S2000
Feb 3, 2010 01:33 PM
xionl1350
Feb 23, 2007 03:34 PM
661rex89si
Aug 13, 2006 12:45 AM
Ignitecivic
Dec 18, 2001 11:12 AM
