Ignition Coil?
Old Jul 19, 2007 | 02:33 PM
Lb1atx's Avatar
Default Ignition Coil?
How do you know if your ignition coil is bad? how do you change out your ignition coil? does anyone have a "how to"?
Old Jul 19, 2007 | 05:01 PM
Lb1atx's Avatar
bump
Old Jul 19, 2007 | 06:06 PM
Sam92Teg's Avatar
Default Re: Ignition Coil? (Lb1atx)
The coil can be tested.
Simple search took 10 seconds for this helpful link. https://honda-tech.com/zerothread?id=669932
Old Jul 19, 2007 | 07:59 PM
hard charging 929's Avatar
Alot of the coils that i've changed out at the shop you can see where it shorts to the housing. The housing is all black and it's kind of hard to describe but if you saw it you'd know it right away. Discoloration of a roundish area on either side of it.
To take it apart, take the cap off(leave your wires on).
make a reference mark on the top distributor housing mounting point,dist.and bolt(makes it easier to put it back on)
You'll have a screw holding your rotor on, take that out, don't loose it. There's a black cover that shields the coil,ignitor,wires, take that out. and the coil is the big black piece.
Take a before picture with a pic phone or digital camera for ref.
I believe it's like 2 or bolts holding it in and some wires on it. Take those out, lift it up and look it over.
All the ones that have gone up at the shop have a clear short to the case. So i'm assuming if your's is bad it'll have the same short on the case.
Hope it helps
Jeremy Dunn
Jun 20, 2017 11:49 AM
Pete_SI
Apr 27, 2004 06:15 PM
duckming
Jun 3, 2003 12:31 PM
gtconcepts
Dec 7, 2002 04:31 PM
