removing/replacing rocker panels with rivets
i was wondering if it is actually possible to use heavy duty rivets to keep the rocker panel on rather than welding. a shop owned by a friend of mine said it will work fine, but I'm not sure how to do this. anyone else have any tips to doing this or think its a bad idea?
ok well forget that idea. i want to buy a good welder to do this job. im confident i can weld in new quarter panel and rocker panel rust repair panels. doesnt sem to be too hard or a job. my only question is, should i use a gasless wire welder? and do they plug into a normal A/C outlet in a home?
What you're going to be spending on a welder, and practice to get it right, you might as well find a small body shop to do it for you.
Gasless (flux core) welders suck, it's like spitting boogers on the metal. I hate those things.
A good MIG setup is going to cost you more than the car's worth.
It's not as easy as it seems either. If you don't have experience in metalwork/body metalwork you're in for a treat.
I've replaced body panels using rivets before, and on a rocker it's no big deal. It's a bit more work than welding. There's a body panel glue out on the market now, I can't recall the maker/brand name or anything, just know that I've seen it on some tractor forums before.
ok well thanks, i'll just have a shop weld them in, and i'll grind/shape the welded areas
should i lay epoxy primer over the welded area, and then bondo, and then filler/sealer, then paint?
b18LS
Paint and Body
Jun 9, 2007 04:15 PM
I3ackfire
Apr 27, 2004 12:31 PM
