sohc zc swap (dpfi-mpfi) running rich...help
Old Jul 19, 2007 | 10:06 AM
gwiffer's Avatar
Default sohc zc swap (dpfi-mpfi) running rich...help
Black smoke (& slight oil contamination)
Specs:
90 STD HB
Sohc ZC (burns no oil)
DPFI-MPFI (w/ 10ohm 10W inline resistors)
Chipped PR4 w/ PM7 maps (PM6 maps didn't help)
Ported STD header
Charcoal Canister removed
PCV removed
ECU finally threw O2 sensor code (1), but I do not know if it was just fouled up or not (this happened only after driving for a little while). I will try another O2 sensor ASAP.
Would the inline resistors cause this as opposed to a resistor box?
Modified by gwiffer at 5:05 PM 7/20/2007
Old Jul 19, 2007 | 12:01 PM
hondacivic90zc's Avatar
Default Re: sohc zc swap (dpfi-mpfi) running rich...help (gwiffer)
i have a 88 crx dx with a sohc zc swap and dpfi-mpfi. For the fuel injection swap i used a stock si harness, the pm6 ecu, and the resistor box. But i have the same problem as you, i am running rich and throwing an o2 code. I noticed my timing belt was off and my cam was two teeth advanced and i ran it like that for 2000 miles before noticing so at first i thought that was just my problem. Before i changed the timing i was getting 27 mpg city and after the timing i got 35 mpg then 33 mpg and now 27 mpg again and i still throw the o2 code. The timing has not jumped teeth again and it still is running rich. I have changed o2 sensors with no luck. I have been trying to figure this out since april '07 when i did the swap with no luck so far.
I am also very interested in figuring out this problem so any progress you make please post it.
Is your motor vtec or no because i know they made both vtec sohc zc's and non vtec versions. Mine is not vtec.
Old Jul 20, 2007 | 10:45 AM
gwiffer's Avatar
Default Re: sohc zc swap (iandavis90)
non-vtec, i checked the timing (cam) when i put the motor in
i'll check it again since its been a while
if anything, i'm sure I can just use turboedit and a chip burner to trim the fuel down a little once i get my wideband
Also, i will check the tps wiring to make sure that I pinned it correctly (mpfi).
Old Jul 21, 2007 | 09:01 PM
gwiffer's Avatar
ttt
Old Jul 22, 2007 | 09:58 AM
welfarepc's Avatar
get another o2 sensor from the junk yard (an OEM sensor). if it doesnt work you can go back and pull another one. dont buy a bosch sensor, ive read nothing but bad things about them. i have a bosch that has held up well tho.
make sure your timing is set correctly as well
altfuelneeded
25
Sep 30, 2011 10:08 AM
altfuelneeded
Aug 23, 2011 04:42 PM
crex-ef
Jul 21, 2010 09:27 AM
tjscivic
Aug 28, 2009 10:18 AM
