Throttle body question: High Idle/inconsistant vacuum leak....
Old Jul 19, 2007 | 09:49 AM
Ron Burgandy's Avatar
Default Throttle body question: High Idle/inconsistant vacuum leak....
So heres what is going on; when I start my car my idle is up around 2700, which comes down around 1500 when my car is warm....then after it warms up I have a temperamental vacuum leak that pulsates from 1500 - 2500 at a slower rate.... I am not sure what type of throttle body I have since I recently purchased the car, so I have taken some pics. The car is currently running a b16a obd0 and throwing no cel's.
Old Jul 19, 2007 | 10:59 AM
Default Re: Throttle body question: High Idle/inconsistant vacuum leak.... (Ron Burgandy)
Old Jul 19, 2007 | 11:21 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ron Burgandy &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
the captain obvious answer is, i hope you have those two ports on your intake plugged...
other than that, free bump...
Old Jul 19, 2007 | 11:26 AM
Default Re: Throttle body question: High Idle/inconsistant vacuum leak.... (fastcrxsi90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastcrxsi90 &raquo;</TD></TR><TR><TD CLASS="quote">
other than that, free bump... </TD></TR></TABLE>
Plugged, unplugged makes no difference as far as the idle or vacuum leak is concerned.
Old Jul 19, 2007 | 11:27 AM
but yes they are plugged
Old Jul 19, 2007 | 11:47 AM
89efDUSTY's Avatar
Plugged, unplugged makes no difference as far as the idle or vacuum leak is concerned.</TD></TR></TABLE> x2
Check for any leaks by just spraying the motor with carb choke find the area and make sure it seals properly. I don't know B series, but IACV problem maybe? Map? No leaks in lines? IM gasket sealed tight? many factors...gl
Old Jul 19, 2007 | 02:30 PM
I feel like a bonehead.....problem was my idle screw on the throttle body....it was backed out all the way and almost fell out. lol tightened it up and both problems are fixed.
thanks for the bumps guys.
magicguy
Jan 30, 2009 02:00 PM
black bandit
Jan 14, 2008 04:26 AM
jcfreibert
10
Nov 23, 2007 10:51 AM
Civic_95_Si
Aug 8, 2003 10:11 PM
ciRcuitJerk
Jul 6, 2003 09:21 PM
