My Viper alarm is acting weird...
Old Jul 19, 2007 | 08:55 AM
AP Kreuzer's Avatar
Default My Viper alarm is acting weird...
i have a viper 791xv 2 way alarm installed in my car. i dont know what happened but the range isnt far like it was use to. i cant even unlock my car from inside my house. also on the remote the icon shows that my car is unlocked but its locked. any ideas? has anything like this happen to you guys? could it be bad installation?
Old Jul 19, 2007 | 09:59 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: My Viper alarm is acting weird... (EP Kreuzer)
have you droped the controler?
Old Jul 19, 2007 | 10:40 AM
AP Kreuzer's Avatar
Default Re: My Viper alarm is acting weird... (wrx-killer-Sti-eater)
yeah i dropped it couple times
Old Jul 25, 2007 | 09:17 PM
sil04ver's Avatar
Those remotes are notoriously fragile (at least the old style). Not sure how the new ones are.
Old Jul 27, 2007 | 06:16 PM
duwa's Avatar
ok, the viper alarms has a antenna (receiver).it has to be in the windshield since it is the place to have more clearance for the 2 way. i think that for this model it has and antenna about 7 in. long. the best place to put it is behind the rear-view mirror. this is because there is no objects that may block connection, and in some cars it just blends in with the black thing that they stick into the windshield behind the mirror.
other things that may help=
1) wiring connections---soldering the connections is the most dependable
2)proper antenna mounting--- it should not be mounted under the dash or against metal
3)proper antenna routing--- the antenna wire has to be routed the best way possible.if the wire is to long do not make a "ball of wire" and hide it.if you do this it will loose range ability.
finally, yes i can be the way it was all connected make sure that who ever does your alarm set-up, is MECP certified. 2 way alarm is not the same as the simple alarm system
mark2583
Audio / Security / Video
Nov 18, 2009 05:51 AM
civicsi24
Oct 23, 2009 03:22 AM
SouthFlorida-ITR
Nov 26, 2005 05:18 AM
is3oo
Aug 15, 2004 07:38 PM
Ants
Aug 3, 2002 08:41 PM
