need help with b16 swap
Old Jun 9, 2002 | 06:38 PM
90SIhybrid's Avatar
Default need help with b16 swap
i just finished dropping in the b16 , I tryed to start it and it cranks over but it won't start.what should i check to figure out what the hell is wrong with this thing .tomorrow i'm gonna check the ignition system to see if it has a spark,the vacum lines to see if i did anything wrong.I checked all my grounds already adn they seem to be fine .if anyone has any ideas please give me your 2 cents it might help.
Old Jun 9, 2002 | 07:02 PM
hybridsol's Avatar
Default Re: need help with b16 swap (90SIhybrid)
I would check:
(1) Fuel pump comes on when you turn the key
(2) Fuel pressure (gas in the car?)
(3) Other elecronics work (lights) checking for grounds (all 5)
(4) stupid things- firing order of plugs, harness connections...
Is it throwing codes? My first attempt at starting did not work- I had 4 of the 5 grounds connected. Go figure.
Vacuum lines won't keep it from starting, just idling well.
Sean
Old Jun 9, 2002 | 07:14 PM
BABYGIRL ITR's Avatar
http://hybrid.honda-perf.org/tech/4gtech/eb-4g0.html hope it helps
kc_kc
16
Dec 3, 2010 06:02 AM
jayc
23
Nov 3, 2009 07:02 PM
crxracer2006
Sep 22, 2005 11:46 AM
91_civicsi
17
Jun 11, 2004 08:26 PM
