90 CIVIC SI HB DPFI TO MPFI
I have a 90 civic hb that I swaped to a MPFI and I am having some problems with some codes I can't figure out. It is code 4 & code 16 the crank angle sensor & in jector code can anyone help please.
It starts up and everything but it doesn't run right and seams like it is loading up when I rev it up. I have everything I need like injector resistor box, ECU (PM6), harness evrything but I can't figure it out.
Thanks
Thanks
I would go back and re-check that the wiring connections are solid and that you used the correct gauge wire. Those are the two most common issues encountered during a MPFI swap and are usually the result of bad wiring.
I checked the wiring and found that the crank angel sensor wires wasn't hooked up. But now they r and the injector code is gone but the crank angel sensor is still flashing. The crank angel sensor wires r orange (c1) and white (c2) correct and coming from the round 7 wire distributor plug, right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AEC_SI_04 »</TD></TR><TR><TD CLASS="quote">What the hell is a dizzy</TD></TR></TABLE>
A stupid slang term for people that can't spell distributor or can't type dist.
I have a new si distributor, ecu and everything I need. I think my problem is in the wiring for the dist. I found the white c2 wire in the shielded cable, but I can't find the orange c1 wire.
Modified by AEC_SI_04 at 8:00 AM 8/22/2007
grg9988
Feb 29, 2008 12:13 PM
mugenwannabe
19
Dec 25, 2003 11:40 AM
milruner
Dec 14, 2003 06:48 PM
ahc'monracing
Oct 5, 2002 10:12 AM
